It is currently Wed Dec 31, 2025 10:24 pm
 Post subject: BBD Question
PostPosted: Fri Dec 07, 2007 5:36 pm
I finally found a super 2 manifold. It was in a junk pile at a local boneyard-been laying out in the weather for many years. The intake is ok, but the exhaust won't survive. This setup had a BBD carb on it that looked to be in terrible shape, and I was going to throw it away. SInce the weather here has turned bad, I decided to take a look at the carb. After I FINALLY got it apart, it is clean as a pin inside and I have everything cleaned up in good shape. Quite a surprise to me. Now I need to find out the approx. year it was used, if possible. The only #s on the carb are 0- 2425 under the Carter logo. It has the pcv port, and a port for the choke pull-off. The only other port on the other side looks like a vacuum advance port. Definately older than my 85 truck, whick has about a dozen holes in it. Is there any way to pin down the appeox year on this carb? Sorry for such a long post, and thanks in advance for any help.
ken
Retired old Goat rebuilding a old Goat.
(85 Ram 150 /6)
PostPosted: Fri Dec 07, 2007 7:11 pm
Those casting numbers won't help ID the carb, but if you post some good, clear pictures, we can probably get you fairly close by visual ID.
PostPosted: Sun Dec 09, 2007 10:00 am
Place the top on it without the gasket and check for flatness and gapping. The tops warp. I flattened one with a table top belt sander in about 40 seconds. Probably do it on a flat surface with some grit paper.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
Users browsing this forum: Bing [Bot] and 11 guests
