It is currently Sat Jun 20, 2026 2:25 pm
 Post subject: cam failure
PostPosted: Sun Dec 16, 2007 11:03 am
I need help picking out a new cam for my 65 dart.it has an orignal dutra intake,very mild portwork ,its about 10 to 1,it had the biggest mopar cam you could get(5.28?)it ran 15.80 in the 1/4 mile@ sac this year.any helpwould be great.
PostPosted: Sun Dec 16, 2007 1:40 pm
Doctor Dodge is the man to talk too......
If you want to browse, I have to suggest Schneider Racing cams....they have some interesting 'big' grinds and are very reasonable on a re-grind.
 Post subject: cam
PostPosted: Sun Dec 16, 2007 2:48 pm
the mopar 528lift cam was a nice one, i ran a best of 14.20et at 3070lbs,3.91gears and 3900 converter,with big valves and 10/1comp.with your mild porting, compression is good, mybe a cam in the 270dur/.490lift range would be better. is your car street setup? :)
PostPosted: Sun Dec 16, 2007 5:42 pm
Check out the special deal, from Erson Cams, for Slant Six.Org members.
