It is currently Sat Jun 13, 2026 4:26 pm
PostPosted: Thu Dec 20, 2007 7:01 pm
take a broken stud out that holds the manifold on a 225 or do i not need every single one curious.. thanks
Dave
87 d150 2bbl carb 225
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
89 f450 diseal 4x4 dually 5sp
PostPosted: Thu Dec 20, 2007 7:53 pm
If there is any of it above the face of the head you can try welding a nut to it and twisting it out.
If not, drill it out and retap the hole.
PostPosted: Thu Dec 20, 2007 8:01 pm
ur right im sure i can weld a nut to it with my miller mig 250 :D isnt there such thing as a stud extractor ?
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
 Post subject: broken stud
PostPosted: Fri Dec 21, 2007 6:29 am
yes there is a stud tool but you need enough of the shank above the head surface for the teeth on the tool to bite. i like the nut /weld job, the heating and cooling helps break the stud loose :lol:
 Post subject: Old trick...
PostPosted: Fri Dec 21, 2007 1:08 pm
If the stud is hot enough and you apply a bit of wax around the base it can suck the wax/paraffin into the threads (like soldering copper pipe) and loosen things up (had to do this trick a few times on the rear oil galley plug...)
PostPosted: Fri Dec 21, 2007 3:47 pm
I just did that last Saturday. Broke a tap off in the head, at the last exhaust bolt location, even worse than breaking a stud, easy outs are nice but a broken tap? ....... I finally got it out plus a heli-coil that I didn't know was in there. Used Lots of Kriol and was able to work it out with a punch and a ground down and slotted four pronged socket that I made.
That stud would never keep leaking no matter what lock-tite compound I used. It is now JB welded in with a new heli-coil. The head is only about 3/8" thick at that location.
PostPosted: Fri Dec 21, 2007 4:34 pm
alright guys im going to put a bigger nut on there and plug weld it horizontal solid wire mig 35mm wire short circuit 18.0 volts 4 wire speed. cuz im good like that illl let you guys know how that goes luckily im becoming a certified welder :D
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 2 guests
