It is currently Sun Jun 21, 2026 11:35 am
 Post subject: Fuel injection rail?
PostPosted: Fri Dec 21, 2007 12:24 pm
In the Articles section of this website Doug Dutra wrote a piece on building your own fuel injection manifold and fuel rail. It appears that the part about the fuel rail was never completed, but my question is about the bungs (bosses) Doug used in this mod. In the article he says "What I did was modify a plumbing supply ?" NPT OD x 1/8" NPT ID x 1" long "adapter bushing", machined into "screw-in bosses" ( ?" NPT OD) and a stepped, smooth-wall ID, .437 through & a .540 to .550 (14mm) counter-bore (~ 9/16"). (**See Sketch**) "
There is no sketch, and I'm having trouble picturing in my mind how this would all fit together. Will this accept most injectors? Like the GM V6 stuff? Can anyone make this bung assembly a bit clearer? Thanks!
________
vapor genie
PostPosted: Fri Dec 21, 2007 4:31 pm
PM DOC or Dr Dodge on this board He is Doug Dutra.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
