It is currently Wed Jun 17, 2026 4:09 pm
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3
PostPosted: Fri Dec 21, 2007 7:38 pm
Can one explain the reason behind reversing the lobes for cyl 4, 5 and 6?
That's very interesting.
Cheers, Wizard
PostPosted: Fri Dec 21, 2007 7:59 pm
Cylinders 4,5 and 6 are in mirror image to 1,2 and 3. The layout from front to back is
EI EI EI IE IE IE. The back three have to be mirrored to the front 3. At least that's what I take it to mean.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Dec 22, 2007 12:41 pm
Did the Toyota casting take to welding? The ls1 is 356 alloy that welds really well. I actually used a large press to remove warpage incured while welding. No cracks or damage.
How did the bore spacing work out, any overlap? Did you cut and join two sections or three?
PostPosted: Sat Dec 22, 2007 7:57 pm
While searching around for 4" bore spacing heads I came upon the DOHC Northstar/Aurora engine. The Aurora is 87mm bore so it's valves would fit down a slant cylinder. They use 4 bolts per cylinder too.
PostPosted: Sat Dec 22, 2007 8:44 pm
Car Model: 1964 Valiant
Don't forget the classic Jaguar inline six. It also has a 4 inch bore
spacing. There are four bolts around each cyclinder, but the
pattern is slightly wider to allow for the overhead cams. The
water jackets in the example I saw was in the same place but probably not the oil passages.
PostPosted: Sun Dec 23, 2007 6:02 pm
Is it time for the annual winter aluminum head thread yet? :lol:
PostPosted: Sun Dec 23, 2007 11:27 pm
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
Its summer here......
Richard (aka Fingers)
PostPosted: Mon Dec 24, 2007 3:10 am
:lol: :lol: :lol: :lol:
PostPosted: Mon Dec 24, 2007 6:39 am
I believe so :roll:
Chris'
Autobody
Restoration
Service
