It is currently Fri Jun 05, 2026 7:16 pm
PostPosted: Fri Dec 28, 2007 2:46 pm
The results are in...I averaged 23.6 MPG for calendar year 2007. It's a 15-mile commute to work through 28 traffic lights at 45 MPH max, and a 20-mile trip home on the freeway at 55 MPH.
The car is a '64 Valiant, pure stock except for a Pertronix unit and larger exhaust [plus my ultra-secret proprietary air filter housing modification). Three-speed 225 with 3.55 axle and Carter BBS carburetor.
Not too shabby for a 43 year-old technology...
 Post subject: Yearly Mileage results
PostPosted: Fri Dec 28, 2007 2:54 pm
Great going!
What part of the country do you live in?
PostPosted: Fri Dec 28, 2007 2:57 pm
Phoenix, Arizona, which is a contributory factor to good MPG.
PostPosted: Fri Dec 28, 2007 3:26 pm
What do you have the timing set at?
PostPosted: Fri Dec 28, 2007 4:03 pm
8* BTDC. I usually pull 20" to 21" of vacuum at the manifold.
183,000 miles with the original OEM clutch, too!
PostPosted: Fri Dec 28, 2007 7:07 pm
Good Job!
Now I wonder what can be done to average 25 MPG... :? :wink:
PostPosted: Fri Dec 28, 2007 7:29 pm
Good indeed! You should feel proud of your ride. You might try the NGK plugs with the extended tip. Maybe you can squeeze a bit more out of her. I think the number is ZFR5N.
Sam
PostPosted: Sat Dec 29, 2007 3:15 pm
Great work. There are not too many new cars on the road with that kind of real world average, alas. The stick really helps out, as I discovered.
