It is currently Sat Jun 13, 2026 5:59 am
PostPosted: Sun Dec 16, 2007 9:41 am
Pump it twice and mine starts with about a 1/2 a turn on the crank with quite a bang. Kind a gets your attention......... The extra compression is nice to have on those cold mornings.
PostPosted: Sun Dec 16, 2007 9:54 pm
68 Barracuda
Thats what I am doing from my headers on my 66.
Frank
Thank you
3 questions
1.) Long or short Headers? - I am looking to improve my torque curve
2.) Do you use 2 1/4 all the way to the back?
3.) Do you use a Crossover?
oh yes remember i cant count :D
4.) What carb setup are you using?
Regards
Fanie
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Thu Dec 27, 2007 8:45 pm
At this time, myself, I run 2 1/4 for the first three feet and 2 1/2 all the way back and it isn't to loud at 70-75 mph. I run a magnaflow muffler and I'm preatty happy. I have a super six and an open air cleaner.
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
PostPosted: Thu Dec 27, 2007 10:18 pm
Long headers create the most torque. Short primaries do not do much for torque.
If you collect them run a single 2.25 all the way back for the most torque. Try to run the "Y" at least 4' to 6' back. That will help provide more torque.
If you run duals, use an "X" pipe crossover, it helps create more torque verses the "H" type. You could run 2.5 or 2.25 off the collectors to the crossover then 2" behind the mufflers. Most modern performance cars use this type of set up. My daughter's Audi A6 is configured this way. It is has an amazing amount of power for a 6.
 Post subject: Exhaust Size
PostPosted: Fri Dec 28, 2007 3:14 am
HEY ALL
MY ozzie 225 vaialnt is fitted with a 2 1/2 system with extractors and as single "s" pass style muffler its a little loud when you open it but other wist a kinda nice sound
the black sheep
i like it lumpy
PostPosted: Fri Dec 28, 2007 3:45 pm
Does the reduction from 2 1/4" to 1 7/8" at the tailpipe affect mileage at all? I'll deal with the noise if it does.
Also, whats a good quiet/normal sounding muffler for these things? I'm not looking to impress anyone but I'd like a quality/non glasspack sound out of it.
PostPosted: Fri Dec 28, 2007 4:39 pm
Walker makes a good quality quiet muffler. They are very close to stock.
I went with 2 1/4 all the way back to improve mid to top end power. Basically the time it takes to get from 40 to 60 on a on ramp can be felt with the larger pipe all the way back. With the smaller pipe, it will do it but not as quickly.
