It is currently Thu May 07, 2026 2:20 am
PostPosted: Mon Sep 09, 2002 6:34 pm
I took out the tranny and will be buying a new clutch... The pressure plate was bad, and everything ells was in need of changing. This was taken out of my 67 plymouth signet. Is this a "526 tranny?" Just wondering. Have a nice day!
PostPosted: Mon Sep 09, 2002 9:13 pm
: I took out the tranny and will be buying a new
: clutch... The pressure plate was bad, and
: everything ells was in need of changing.
: This was taken out of my 67 plymouth signet.
: Is this a "526 tranny?" Just
: wondering. Have a nice day!
Looks kinda like an A-903, but I'm not the expert on early trannies..hope someone has a more solid opinion on the subject...
PostPosted: Mon Sep 09, 2002 10:23 pm
No bump on the top cover so it's the standard duty 903 3-speed, the "heavy duty" one is called a "745".
Both types have a non-syncrow first gear, column shift linkage 3 speed trans.
Hate to say it but these things are no fun to drive. (kinda like driving a farm tractor)
See if you can find an 833 4-speed set-up for the car.
PostPosted: Tue Sep 10, 2002 7:09 am
: See if you can find an 833 4-speed set-up for
: the car.
: DD
Bolt....where, (generally), are you located? If you decide to do as Doug suggests, I've got a complete A833OD setup from a van that I could make you a really good deal on. You'd have to shorten your driveshaft and come up with a shifter, but.......
Roger
GTS225@aol.com
PostPosted: Tue Sep 10, 2002 7:41 am
i always thought those trannys would make neat looking barstools.
-james
ludite13@cs.com
PostPosted: Tue Sep 10, 2002 8:38 am
: I always thought those trannys would make neat
: looking barstools.
: -james
I have a pile of these 3-speeds I would sell for "a song" if you want to try-out your barstool idea !
(no-one really wants these things now-a-days)
 Post subject: Re: 903
PostPosted: Tue Sep 10, 2002 12:12 pm
I have a 745 in one of my vans - and want to switch it out - any suggestions?
Dan
PostPosted: Tue Sep 10, 2002 7:15 pm
I am very pleased with the slant-6. With a new clutch in the car I was able to drive it for the first time. This little car was a blessing and came at the right time. With your help, and the Lords all the mechanical work went very smooth. :)
PostPosted: Tue Sep 10, 2002 9:08 pm
Hmmm what's wrong with farm tractors? The new ones have 30 gear drive speeds and no clutch!
cfield@ll.net
PostPosted: Tue Sep 10, 2002 9:36 pm
: Hmmm what's wrong with farm tractors? The new
: ones have 30 gear drive speeds and no
: clutch!
Wow, the last tractor I drove had a no syncrow tranny and a shift mechanisum which needed a searchlight so you could find a gear.
Sounds like I need to get out of Silicon Valley and back to the farm, to check-out some of the new equipment.
PostPosted: Tue Sep 10, 2002 10:29 pm
: No bump on the top cover so it's the standard
: duty 903 3-speed, the "heavy duty"
: one is called a "745".
: Both types have a non-syncrow first gear,
: column shift linkage 3 speed trans.
: Hate to say it but these things are no fun to
: drive. (kinda like driving a farm tractor)
: the car.
: DD
I think I had one of these in a red '63? Valiant convertible I owned about 30 yrs ago. It had Hurst floor shift linkage, and a fiberglas tunnel.
fglmopar@aol.com
