It is currently Fri Dec 26, 2025 3:41 am
 Post subject: What size tires?
PostPosted: Mon Dec 31, 2007 12:44 am
I have a 63 Dart, and it needs new front tires. I will be running 14X7 slot mags. What size tires should I run. Is a 185 70 14 too narrow for a 7 inch rim? If so, what should I get?
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Mon Dec 31, 2007 1:06 am
I'd get 205/70 14
PostPosted: Mon Dec 31, 2007 8:16 am
You can run up to 235/60/14
PostPosted: Mon Dec 31, 2007 9:42 am
I have 235 60 14 in the back. I want the skinniest I can in the front without any tire wear problems.
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Mon Dec 31, 2007 10:47 am
Then you need to get a narrower wheel. I wouldn't run anything skinnier than a 195 section on a 7" wheel. 6" slotted mags are all over the place.
PostPosted: Mon Dec 31, 2007 4:08 pm
So a 195 wont wear funny?
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Mon Dec 31, 2007 4:24 pm
If you are looking for a drag wheel/tire or a cruise night look....thats one thing....do whatever......or swap them on for the event.
But if you drive hard on real roads, wet roads, snowy roads.... you will soon discover what it is to "plow"......
whats wrong with the 7"slots 235s front and rear look?
PostPosted: Tue Jan 01, 2008 1:50 am
Too wide for me in the front. I want sort of a street/strip look. I'll probably go with 205 65 14 in the front and 225 60 14 in the back. I have 235s in the back now, but they are too wide a rub a little, even with the fender lips rolled over.
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Tue Jan 01, 2008 1:57 am
Don't forget that the same tire on a wider rim will be wider than if it was on a narrower rim (.2" tire width change per .5" rim change)
and
tire widths vary form manufacturer to manufacturer.
Tirerack has specs on the various tires
