It is currently Wed Apr 29, 2026 8:33 am
PostPosted: Tue Sep 10, 2002 9:06 pm
I talked to a couple of offline (e.g. "Computers are the work of the devil...") slanters at a local tranny shop last weekend. They asked if anyone had adapters yet for running other trannies. I explained the stock mopar adapter to allow use of an "LA" block Tranny (904,727,500,518,998,999,etc...). One guy was very interested in an adapter for a slant to a Chev 700R4. I thought a while back someone had adapted a Powerglide to a slant for draggin'
Does such an adapter exist? Are they willing to machine another unit?
thanks, gotta get these guys on line (they're missing out!!!!!)
 Post subject: *bump*Anyone? *NM*
PostPosted: Thu Sep 12, 2002 6:12 pm
PostPosted: Fri Sep 13, 2002 8:46 am
Mark Good man is the only one I know of who has done this, his team put a Powerglide behind a SL6
This is "one-off" custom machining, I do not know of anyone offering this type of adaptor as a catologed / p/n item.
PostPosted: Fri Sep 13, 2002 9:27 pm
I kind of expected this. I thought he might have patterned a spare (always good to have two of an "experimental item"...)
I'll just tell the guy if he wants to go that route to take an A-904 slant housing and his 700R4 to a machine shop...
thanks doc, really appreciate it.
: Mark Good man is the only one I know of who has
: done this, his team put a Powerglide behind
: a SL6
: This is "one-off" custom machining, I
: do not know of anyone offering this type of
: adaptor as a catologed / p/n item.
: DD
PostPosted: Mon Sep 16, 2002 12:21 pm
My slant six FED has a mid-plate made to adapt the slant to powerglide. I believe Mark Goodman made mine for Dick Weber (prior owner). It uses a TCI mopar SB to 'glide flexplate kit, with one hole in the flexplate moved.
I am in the process of copying the midplate in order to run a 904 (Slant version) instead of the powerglide.
mldingba@rockwellcollins.com
Users browsing this forum: Amazon [Bot] and 1 guest
