It is currently Tue Nov 24, 2026 9:16 pm
PostPosted: Tue Jan 01, 2008 2:19 pm
I am planning to send out my midwest converter for a stall adjustment. In the meantime I was planning to run a stock converter from a 72 challenger that had a 904. Will there be a problem in terms of fittment and being able to drive the car for about 2 weeks? I have the large crank pilot and have also switch over to large pump and input shaft.
PostPosted: Tue Jan 01, 2008 3:51 pm
As long as the converter matches the register on the crank and the input shaft you should be fine.
