It is currently Tue Nov 24, 2026 12:54 pm
 Post subject: 7.25 axle swap
PostPosted: Fri Jan 04, 2008 8:19 am
I want to convert my 70 valiant to disc brakes and large bolt pattern, so I bought a 74 dart 318/904 7.25 for parts. I thought all 7.25 rear axles were the same c-clip design but after doing some searches on slantsix forum now im not sure if I can just swap axles between these two cars or do I need to change entire rear ends? I like my gears now and I havent checked but I am afraid the Dart will have taller highway gears, higher than 3:23. Has anyone done this swap or know if they will interchange?
p.s. just thought about brakes, im not sure if they have the same size drums if not I may just swap the whole axle.
70 Valiant 225,super six
65 Dart More Door race car 225/4bbl 8 3/4 3:91
70 Dodge D100 Sweptline short box 225/4spd
PostPosted: Fri Jan 04, 2008 8:54 am
You have to swap the entire rear end. The axles are the same length, but the bearings and backing plates are set toward the center of the housing (which is narrower) to accommodate the wider rear brakes of the later cars without increasing the track width. Also, 7 1/4s didn't get C-clips until much later.
PostPosted: Fri Jan 04, 2008 9:38 am
Its easy to swap early gears into a late housing.
PostPosted: Fri Jan 04, 2008 12:33 pm
Thanks, I will swap the entire rear then.
Users browsing this forum: Amazon [Bot] and 1 guest
