It is currently Sun May 17, 2026 9:22 pm
PostPosted: Sat Jan 05, 2008 4:51 pm
The horn button on my 63 Dart is loose. How do I tighten it? or remove it?
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Sat Jan 05, 2008 5:10 pm
It just pries off the horn ring. Use a craft stick or a screwdriver without sharp edges (or a credit card) to avoid marring the plastic button. If it's no longer a tight fit in the horn ring, replace its rubber O-ring or shim it with a piece of paper.
PostPosted: Sat Jan 05, 2008 5:15 pm
The whole horn ring is loose.
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Sat Jan 05, 2008 5:25 pm
6 Pack Dart
does it have the spring under the horn ring like it should have, or is the spring weak or broken.
PostPosted: Sat Jan 05, 2008 7:23 pm
I like the custom floor vent :D :wink:
PostPosted: Sat Jan 05, 2008 7:28 pm
We prefer the term "Pavement Inspection Port", thank you.
:lol: :lol: :lol:
PostPosted: Sat Jan 05, 2008 7:45 pm
:lol: :lol: :lol: :lol:
I like that one!
PostPosted: Sat Jan 05, 2008 7:54 pm
Ah, OK. To remove the whole horn ring, pry off the centre button as described, remove the horn ground wire from the horn switch, remove the three philips-head screws and lift the horn ring carefully off the steering wheel, making sure not to lose the three plastic bushings that go between the philips head screws and the horn ring body.
PostPosted: Sat Jan 05, 2008 9:36 pm
Ok, so in theory, when I take off the cover, I should be able to tighten the horn ring down?
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Sun Jan 06, 2008 2:49 am
unless the plastic bushings are broken and/or missing.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Jan 06, 2008 10:13 am
I'm sure they are broken too. :x
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Sun Jan 06, 2008 12:48 pm
OK, today I took the cover off with a credit card, as said above, and tightened the horn ring. 2 of the screws were loose.
1970 Nova 12.53@108
1970 Bug 15.38@87
