It is currently Thu May 21, 2026 4:03 pm
PostPosted: Fri Dec 14, 2007 6:43 pm
are they the same for the small blocks?
i am getting the Tremec TKO-500( :D ) in about a month and i am trying to get a list a parts of what i'm going to need. i will also keep everyone updated on bell housing mods for this.
I will be getting a clutch from SPEC clutch.
also how reliable is the stock flywheel? i have seen them in multiple pieces, but that is usually after a clutch failure. if i'm going to do this, i'm going all the way.
sorry for all the questions and i'm sure there are more to come. thanks in advance for the help. this board is always a great place to get good advice.
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
PostPosted: Sat Dec 15, 2007 2:43 pm
I think the stock fly is fine, but others may disagree. Seems like PP explosion would be the cause of catastrophes.
I believe TOB and pilot are same for SB Mopar, but not absolutely sure.
PostPosted: Sat Dec 15, 2007 7:29 pm
Are you asking if tob's and Pilot Bearings are the same beetween a slant and small block, than yes. If you mena betwwn a tko and and 833, not sure there.
pressure Plates do Explode!!! and break rare bellhousings in the process!!
http://www.slantsix.org/forum/viewtopic ... 07&start=0
But anyway to avoid future exlposions I got a Billet Steel flywheel from McLeod - I didnt want to go through any of that again. and besides it was only about $300 and your spec pressure plate should bolt to it if it is in the stock pressure plate bolt pattern.
McLeod can be hard to get on the phone - but here's the part# for the flywheel..
Flywheel (listed for a slant six) - #464001
http://www.mcleodind.com/
(714) 630-2764
They were bought out by B&M and I am not sure if it's easier to get thm on the phone now or not.
But the phone Process is dial number - If you get a busy singnal hang up and repeat for hours on end.
PostPosted: Sat Dec 15, 2007 9:17 pm
the reason i ask is because i need to know how much is different between the slant and small block. the shop that i'm getting the TKO from is going to supply much of the parts i need to do the swap. but, being a slant six, i will be responsible for parts that are different(clutch and bellhousing, so far). i know the TKO has a 26 spline input shaft, but i am not sure about the pilot bearing part. i have e-mailed spec clutch to see how much it will be to make disc a that fits.
Greg, i saw the pictures of the carnage when you first posted them and i DO NOT want that to happen. i'm kinda attached to my feet. what did your flywheel cost? do you think the stock flywheel would be ok with a better clutch?
zedpapa
PostPosted: Sun Dec 16, 2007 6:51 am
Zed,
After that Carnage, I would not trust a stock flywheel, All the ones I have come across have small heat cracks on the surface, even efter they are blanchard ground those cracks remain, at least in the ones I use.. They are fine for street use. but since I race quite frequently I wanted tha peace onf mind that the sell wheel gives me, and for the money I felt it's was worth it. I know Lou has had no trouble with his stock flywheels, which is fine. It's really your call.
PostPosted: Sun Dec 16, 2007 7:16 am
Yall might want to CALL Mcleod there was a post just a couple of weeks ago that said the /6 stuff was discontinued, if I read it right.
Just FYI.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Dec 17, 2007 10:24 am
Be sure and get a pressure plate that has the steel plate/ring instead fo the cast ring/plate. This ring is what causes most of the explosions that are seen in clutch/flywheel failures.
Jess
PostPosted: Wed Dec 19, 2007 7:48 am
just talked to mcleod today. they have a slant flywheel on order for early january, but it measures 13.95", 130 tooth ring gear, and accepts either a 10.5" or 11" clutch. list price from them is $391.71.
this is a truck flywheel, right? the guy on the phone didn't seem like he wanted to be very helpful, which kinda makes me want to go elsewhere. anybody know anywhere else to get a flywheel?
zedpapa
PostPosted: Wed Dec 19, 2007 8:26 am
That will not fit in a standard Slant BH. You would need the 11" truck bellhousing, or an adapter to put a SB V8 BH behind the motor.
PostPosted: Wed Dec 19, 2007 10:10 am
that requires floorpan massage, doesn't it? not interested. what are the specs on the smaller car flywheel?
zedpapa
PostPosted: Wed Dec 19, 2007 12:31 pm
IIRC, the standard flywheel is 122 tooth (check Doc's article on this site!) and 10" clutch max. Should not be too hard to get specclutch or someone else to make one.
Also, Passon Performance was on this site a while back and was looking at machining up a billet wheel for someone in England.
PostPosted: Sun Jan 06, 2008 10:50 pm
are the 273 flywheels the same as the slants? i seem to remember reading somewhere that the early ones were.
i found a company that makes the 273 flywheels with 122 teeth on the ring gear and accept the 9 1/8", 9 1/4", and 9.5" B&B and Diaphragm clutches. the company is Wilcap Products & Sharp Equipment Divisions.
http://www.wilcap.com/index.html
i will be calling them to see what they cost.
zedpapa
PostPosted: Mon Jan 07, 2008 3:26 am
I'm not sure but I think the crank hub bolt pattern is different.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Jan 07, 2008 6:41 am
what is the bolt circle for the slant? i looked in the clutch article and didn't see it. also, what is the hub diameter? thanks for all the help on this.
zedpapa
