It is currently Wed May 20, 2026 6:14 pm
PostPosted: Mon Jan 07, 2008 12:56 am
My linkage is binding when I try to change gears. When unhooked I can move the selectors at the transmission threw the gears no problem. When I hook the linkage on it binds up. I went threw the procedure in the book to adjust the linkage but it still binds up
PostPosted: Mon Jan 07, 2008 5:19 am
Worn motor mounts, worn tranny mount, or worn bushings in the linkages. Have you checked all three?
PostPosted: Mon Jan 07, 2008 9:02 am
Did you adjust the tension collar at the base of the steering column?
PostPosted: Mon Jan 07, 2008 9:22 am
Hello,
Very frustrating problem indeed and Dan's comment re. the collar is pointing to an often overlooked problem. Because I didn't realize I had bushing problems I ultimately pulled my 3 speed and put in an automatic when my bushings if redone would have solved the problem. Check those bushings, and they can be made on a lathe if need be. By chance I have a complete good setup including column I could be induced to let go if you feel the need. I got it eventually in case I wanted to go back to 3 on the column, but I don't forsee that now and would rather have someone who can use it do so than keep it stashed in case.
rock
'64d100
PostPosted: Mon Jan 07, 2008 12:58 pm
The top bolt is striped. the one on the bottom is ok. I can now get it to go threw the gears but its very sloppy and binds sometimes. how much for a new bushing. I am going to need all the bushings for all the linkage some time soon. I got it to $#!+ finally and its now movable. so anyone know where i can find the bushing at the column and the part #'s for it?
PostPosted: Tue Jan 08, 2008 3:41 pm
could I get away with using a heli coil on the bolt that is striped? I need a new bushing but i am not sure where to find one.
PostPosted: Wed Jan 09, 2008 12:07 am
I found similar grommets at a local hardware store and turned my own set of bushings. I haven't come across any after market or NOS sets yet. I still have the email a member sent me a while ago on how to adjust the shift rods, if you'd like to see it, I can forward it to you.
Customers keep us in work, if there are no customers, there is no work.
PostPosted: Wed Jan 09, 2008 12:40 am
I have the factory service manual that has the procedure to adjust the rods. my linkage has had issues since i bought the car 3 months ago. The threads for the tension collar are worn with the top one being striped. I would just like to have the parts to replace it before i take it all apart.
PostPosted: Wed Jan 09, 2008 6:30 pm
Mine has become a 2 speed. Sometimes it binds up on the 1-2 shift. It has been enbarrassing! I can use first but need to shift to reverse, then to second.
I bought a 3 speed floor shifter. It will get saved as I am going to a 833OD.
I've never known any of these to work right. Even a brand new 77 Chevy truck! Always the 1-2 shift!
