It is currently Sat May 23, 2026 6:48 pm
Post new topic  Reply to topic  [ 126 posts ]  Go to page Previous 1 2 3 4 59 Next
PostPosted: Fri Jan 11, 2008 8:22 pm
VERY, VERY, VERY impressive. I want two, for both of my Toads. I really appreciate the time you have in this. Very well done. You are also an artist. Mark
PostPosted: Fri Jan 11, 2008 8:50 pm
Sandy and Joshie you are correct, 5.7 heads. Terry You're right about the early hemi valve cover.
And thanks for all the compliments guys.
Franklin
'61 Valiant
PostPosted: Fri Jan 11, 2008 9:12 pm
that carb set up takes alot of room. now set it up with efi....mmmmmmm efi :mrgreen: .
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
PostPosted: Fri Jan 11, 2008 9:14 pm
Oh, wow. :shock:
I wanted to fit one 5.7 hemi head to a 4 banger to better motivate my little '96 Dakota, but the big bore spacing kept me from doing more than think about it. I believe the Jeep 2.5 in my Dakota has a wider bore spacing than the slant, but I'm not certain.
Dare I ask how many hours it took to build this? What the head weighs compared to the stocker? Is the intake manifold welded to the head?
I'm wanting to radically improve the power of my '67 Valiant and this would do it without completely tossing aside the slant. I just don't think I have the time to build such a beast. My friend with the mill and lathe lives too far away. I used to go to his place daily, but now I live 50 miles away and have a real job and a family.
PostPosted: Fri Jan 11, 2008 9:33 pm
*thundrous applause*
Amazing work.
Still don't understand how you made the large 5.7 combustion chamber work with the small 225 bore though!
So...how long before you're taking orders? ;-) :shock:
PostPosted: Fri Jan 11, 2008 10:16 pm
The 5.7 has a bore of 3.917" and bore spacing of 4.46".............
How did you make it fit ???????? (slant is 3.4" and 3.98/4.00")
PostPosted: Sat Jan 12, 2008 2:47 am
My thinking exactly! Congrats heckshemi...that's an awesome achievement.
DynoDave
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
WPC # 12304
PostPosted: Sat Jan 12, 2008 3:24 am
Wow, this is way more than just pieces of 5.7 heads put end to end.
You have moved the intake side valve cover rail and put the rocker shaft on the other side of the valve, and I guess you had to extend the intake port.
Those look like 426 Hemi exhaust rockers.
I can see how you get the bigger bore working on the slant, after all the valves move towards the center of the cylinder when they open so they will open up in a smaller bore.
How are your pushrod angles? And does it have good water flow around the chamber the way to use to?
So how are those shafts bolted down?
More pics please.
Wow, if you can work this out and then get a set of pistons to suit the head this could get interesting.
Jess
 Post subject: More Details please
PostPosted: Sat Jan 12, 2008 6:31 am
Ok, Times up! Spill all the details. We are dying to hear the details of how you made this work. And may I suggest you type up a little article and send it along with some pictures to Seymour. This definitely belongs in an article in the SSRN. Great work!!
Rick
PostPosted: Sat Jan 12, 2008 7:21 am
Fantastic!!!
I think he is using the ancient chinese secret method now!!!
Waiting for the full review-- very cool
PostPosted: Sat Jan 12, 2008 9:14 am
Black suburbans are headed South as we speak.
 Post subject: Re: More Details please
PostPosted: Sat Jan 12, 2008 9:30 am
Rick
Seriously, I suspect Mopar Action might want to buy an article on that one.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Jan 12, 2008 9:54 am
AWSOME when do you take orders.........or sell your recipe........TELLL MEEEE
It is beautifully done
Anys specs yet?
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Sat Jan 12, 2008 10:56 am
Keep in mind Frank has a better setup in mind.....
PostPosted: Sat Jan 12, 2008 1:44 pm
What did you do for pistons? :shock:
Users browsing this forum: Google [Bot], Pilot01 and 4 guests
