It is currently Tue Jun 16, 2026 5:26 am
PostPosted: Fri Jan 18, 2008 6:34 am
is there anyone who can help me out
1972 Plymouth Duster 225 Super Six Slant
 Post subject: Passenger side...
PostPosted: Fri Jan 18, 2008 6:44 am
It mounts on the passenger side of the block, right behind the alternator/ alternator mount... (not my favorite place if you have to swap one out...you can move it to a location of your liking as long as the wires reach, and you get a ignition wire long enough to go from the distributor cap to the coil...)
-D.idiot
PostPosted: Fri Jan 18, 2008 6:52 am
on the bottom of the alternator bracket?
PostPosted: Fri Jan 18, 2008 7:01 am
Let's clean up the double post.
Here's what I put in the other one:
Right here,beside #1 cylinder, is a stock location:
Some people mount them to the inner fender.
The coil bracket bolts to the block, IIRC. Haven't looked at it since I did the HEI conversion a few years ago.
PostPosted: Fri Jan 18, 2008 7:05 am
sorry about the double post that crap went all page cannot be found and things but i remember taking the coil off along wiht the bracket but i dont remember any holes
PostPosted: Fri Jan 18, 2008 8:17 am
Some of the later model stuff has the bolt holes in the alternator bracket.
I ended all the confusion on my car and mounted it to the fenderwell. :lol:
PostPosted: Fri Jan 18, 2008 9:05 am
well this wasnt the orginal engine for my duster its a super six so thats at least a 77 model engine so that might be it but the bracket that was in the place of the altenator wasnt what a altenator braket should be so i took the one off another motor that is a junker but yeah
PostPosted: Fri Jan 18, 2008 11:35 am
This picture is too small but the original is huge. Save it to your desktop and open with a program that will zoom and make it larger.
http://tinyurl.com/2wlv2r
You can just see the black, metal alternator bracket between the block and the coil. Hold your coil &/or coil-bracket in this same position and you will be able to see which alternator bracket bolt you need to take out to bolt the coil on with - it holds the alternator bracket and the coil with the same bolt. Even if you have a different bracket, this hole should be in the block.
The last two pics here are about the same but I think they open up a little bigger.
http://tinyurl.com/2dp4pe
Danny
PostPosted: Fri Jan 18, 2008 12:18 pm
As previously mentioned, a lot of folks move the coil to the fender well. It gets this part further from engine heat.
http://i62.photobucket.com/albums/h93/H ... ngine2.jpg
PostPosted: Fri Jan 18, 2008 4:49 pm
Mine is mounted on the fender as well. Keeps the wires out of the way and there is no problem with heat.
PostPosted: Fri Jan 18, 2008 5:09 pm
well i will keep that in mind so i suppose puttiing it on the fender would be a better thing between heat and things in the long run?
PostPosted: Mon Jan 21, 2008 10:02 am
I reinstalled my coil and alternator bracket last night to the stock location on my 74 Dart. On one of the terminals on the coil was a short red wire about 1 1/2 inches long with a cylindrical object that obviously needs to be attached to a bolt somewhere. I think this must be some kind of ground, however I don't know where it goes (on one of the two coil bracket bolts?) or if it is should be on the positive or negative terminal of the coil. HELP!
PostPosted: Mon Jan 21, 2008 12:10 pm
It sounds like a radio noise suppressor. I'm not sure if they are factory or aftermarket - mine is held onto the coil bracket with a screw. You can just barely see it in the last picture here:
just over the fuel pump.
Danny
