It is currently Wed Jun 24, 2026 9:18 pm
 Post subject: gasket matching
PostPosted: Sat Jan 19, 2008 7:18 am
Car Model: 1968 A108 225/3 on the tree
details please? just what does it mean? i am prepping to switch to my 2 bbl set up next weekend. i figure i better have some idea what i'm doing.
mostly i'm concerned with the manifold to head gasket.
if i understand it correctly, i want to open up the portal on the receiving end of the flow to the size of the gasket hole. is that rite?
hence, flare the header inlets to the size of the gasket holes, and similarly flare the head portals on the intake ports to gasket size?
or is it an adjustment of the gasket to match the metal sufaces?
D~~~!
PostPosted: Sat Jan 19, 2008 9:37 am
Yes, you got it right. That seems to work best on daily drivers for improved torque.
I just did the swapping of intakes over Christmas. My car was recently rebuilt and the head was already bowl ported/street port and the intake was gasket matched. The exhaust was ported too, but not gasket matched. I did open it up some but not all the way. So my head was already the way I wanted it per Doc's recommendations for mileage and torque.
While I had the manifolds apart I cleaned up the exhaust manifold as far as I could and gasket matched it. Same for the bottom from 2" to 2.25" to match the exhaust pipe.
The original cast iron intake I had gasket matched during the engine build, on the new aluminum manifold I left it stock this time.
The difference seems to be much better torque and better mileage.
I didn't think the exhaust porting and not porting the intake manifold and switching to the aluminum intake would make that much difference, but during the cold weather it brought back the mileage to almost what I was getting last summer.
Racers will open up both sides for max flow.
Hope that helps. :D
I am sure there are folks with many other modifications, but if this is a weekend swap, you can do these mods and get it all back together.
PostPosted: Sat Jan 19, 2008 2:20 pm
You don't need to open up the port to the full size of the gasket.
You just need to smooth things out and match the ports.
A small step (smaller to larger) doesn't hurt anything. However, if you have a step down (larger to smaller) that DOES hurt things.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 10 guests
