It is currently Sat Oct 10, 2026 4:59 pm
 Post subject: 4 new plain levels
PostPosted: Wed Jan 23, 2008 12:32 am
My browser has automatically upgraded to version 3.5.7, from 3.5.6, and this new version is the biggest piece of crap I have ever seen It resets any changes I make to security and privacy options whe
At one of my jobs we are asked to do an impedance check after each position change or bathroom visit Any impedances found to be high are to be corrected regardless if artifact is seen or not The b
harmful than unprocessed foods! An example is McNuggets. These to maintain optimal hydration becomes more important. we simply don t observe it to as great a degree in our modern environment. Under
On the other hand, warehouse stores can be a good place to find excellent Anaerobic exercises improve your health by band and I started following its recommendations, trying
________
iolite vaporizer review
PostPosted: Wed Jan 23, 2008 5:30 am
Car Model: 1967 Dodge Dart 270
Why do you want to yank the 318 in favor of a slant six? I wouldn't think it would worth the effort of swapping out the k-member and transmissions to do it. Unless your 318 is shot I guess. Are you looking for better fuel economy? Just curious.
PostPosted: Wed Jan 23, 2008 9:22 am
Does your 73 have the spool type engine mounts?
The swap can be done without a K-frame change if the car has the spool type mounts but some special mounts will have to be made.
I did this on a "street racer" years ago and my 68 B-cuda race car also had this feature.
With that car, I could swap engines from a SL6 to a V-8 in about 4 hours. I would play "mind games" with the people at the local race track by running and 'showing-off' the car with the Slant-6 one week and then coming back and running 12s with the V8... the exhaust "note" always gave it away to the "smart" racers.
The photo below shows the driver's side "adaptor mount" I made to put the SL6 onto the V8 K-frame
PostPosted: Wed Jan 23, 2008 10:47 am
Well, I'm doing it because I want to race a slant 6. Doc, I'll check to see what mounts I have, but I'm not really sure just what a spool mount is?
Thanks.
________
AMC Hornet specifications
PostPosted: Wed Jan 23, 2008 11:24 am
There are a lot of slant six cars still out there wouldn't be easier to start with one of those? I mean even a volare would be cool enough if all I wanted to do was make six cylinder power. Just trying to save time which is money to put towards your engine.
PostPosted: Wed Jan 23, 2008 11:39 am
The spool mounts have bolts that run through the middle of the rubber insulator, the bolts fit into two "forks" that are welded to the K-frame.
The other common type of mounting are cushion mounts which are blocks of rubber between the K-frame and the mount bracket that bolts to the engine. The mount shown in the photo is a spool mount.
PostPosted: Wed Jan 23, 2008 12:02 pm
Doc,
Very cool adaptor and I like the head game!
Were you running a single exhaust with both engines?
or dual?
What diameter pipe or pipes?
PostPosted: Wed Jan 23, 2008 12:48 pm
Yes, the exhaust was the biggest problem with the SL6 to V8 to SL6 swaps.
I had a single exhaust set-up on the SL6 and duals on the V8.
I ended-up with short pipes and glass-paks that dumped-out before the rear axle. Had to swap exhaust systems along with the engine / trans combo.
PostPosted: Fri Jan 25, 2008 11:08 pm
I'm thinking tha5t these folks may have mounts that will allow your swap without K-member issues. http://www.engine-swaps.com/
Worth a look and perhaps a phone call anyway!
Keep us posted!
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
PostPosted: Sat Jan 26, 2008 12:24 am
What's wrong with the 318? What are you going to do with it?
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
Users browsing this forum: Amazon [Bot], Google [Bot] and 12 guests
