It is currently Mon Jun 15, 2026 11:45 am
 Post subject: Removing trim
PostPosted: Wed Jan 23, 2008 5:11 pm
from the edge of the drip edge. Stainless. Any tricks? I tried a small piece by prying it open on the underside just a bit and it worked (small section).
Is there a better way?
PostPosted: Thu Jan 24, 2008 7:31 am
I just put some tape on a bottle opener (the round end style) to protect from scratching the trim. I jsut start on one end and slowly start prying it off. Lift alittle at a time and it wont get bent out of shape.
Chris'
Autobody
Restoration
Service
PostPosted: Thu Jan 24, 2008 4:38 pm
I use CARS method but also slip a thin paint paddle between the trim and the bottle opener to spread the load a little bit.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
PostPosted: Thu Jan 24, 2008 5:21 pm
OK, so the comb kind with the pointy end and the round end?
Hyper, I was wondering about that, thanks.
PostPosted: Fri Jan 25, 2008 8:16 am
Yes. Some of the "free" ones you get from your favorite brewery seem to work good too, even if they are plastic. You just may go through a few of them if they crack. But they are "free".
Chris'
Autobody
Restoration
Service
