It is currently Tue Nov 24, 2026 10:05 pm
 Post subject: Slant Six Head Gaskets
PostPosted: Mon Jan 28, 2008 7:48 pm
I need some help on the various types and thickness of head gaskets for the 225 what is available? Brand and sources also. Thank You!
PostPosted: Mon Jan 28, 2008 8:56 pm
For head gasket thickness, figure .040 for a Fel-Pro and .045 for all other composite type gaskets.
From the master himself.
PostPosted: Mon Jan 28, 2008 10:49 pm
... and .020 thick for the factory steel shim head gasket but those are not that easy to find these days.
PostPosted: Wed Jan 30, 2008 7:06 pm
d, i just got in 2 .020 shim gaskets, 1947578, 67+older and a 2843182, 68 and newer according to my parts books. other than the 1947578 being a greenish color metal and the pentastar is very detail stamped, they are identical. how much compression can they take? 12-1? will a felpro take more? or less? thanks, ron
PostPosted: Thu Jan 31, 2008 2:58 pm
I run an estimated 10 - 10.5 on my steel shims no Problems there I use the arp Head studs for added safety.
