It is currently Tue Nov 24, 2026 9:38 pm
 Post subject: Ignition timing
PostPosted: Thu Jan 31, 2008 8:33 pm
this may seem a silly question but.........
Is there a difference in timing between a 1 barrel 225 and a 2 barrel super six?
I have swapped to the super six setup.
Any tips or hints would be greatly accepted. :?
PostPosted: Thu Jan 31, 2008 10:54 pm
An increase in CFM alone should not have a major impact on timing but now that you have more CFM the engine can rev higher and that could lead to over advanced spark timing.
Now is the time to check your spark advance and recurve the distributor to match you engine combination and driving conditions.
DD.
PostPosted: Fri Feb 01, 2008 5:51 pm
thank you for the response.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 10 guests
