It is currently Fri Jan 10, 2025 6:07 pm
Post new topic  Reply to topic  [ 50 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Fri Jan 25, 2008 4:14 pm
What cold start drivablity problems should I expect with no heat box?
Thought I'd chime in here on the cold start problems. In the mid 80's I was running Clifford headers and 4 barrel with a 600 CFM Eldebrock on my 65 Dart. No manifold heat at all. Pumped the gas twice and it fired right up, settled into a smooth idle, wait a couple of minutes and pull away. This was in a car I used for daily transportation here in VA (where it does get pretty cold - 14 above this morning)
PostPosted: Fri Jan 25, 2008 5:52 pm
I have a set of the Clifford shorties you can borrow to check for fit on your set-up.
I'll be at the Melbourne Mopar swap meet/car show tomorrow. It's on Wickam Road, near BCC. I bring the headers in case you show up.
Slant Cecil
PostPosted: Fri Jan 25, 2008 6:16 pm
On a V type compressor the support that goes to the block won't fit with the Hookers. I never did fab a replacement.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Fri Jan 25, 2008 7:12 pm
Since you have Tom-Tom, 3719 Wickam Rd Melbourne
Slant Cecil
PostPosted: Sat Jan 26, 2008 3:31 am
Here some pics of a Dart with Hookers, may help you may not.
http://www.flickr.com/photos/mopar/244957092/
Jess
PostPosted: Fri Feb 01, 2008 5:00 am
Those Hooker's would work well, BUT may not fit with some of your mods?
The Clifford Street Rod headers work well and fit well. Not the best possible design, but they've worked well for me. Here is my recommendation:
- Cliff headers
- buy a bona fide Flowmaster or similar Y-pipe with 2.25" inputs and 3" output
- run 2.25" pipes out of the engine bay down to 1" to 4" behind the trans X-member, then into Y-pipe
- 3" from Y-pipe back to muffler in front of rear axle
- Super Turbo or similar 3" ID muffler
- 2.5" or 3" from muffler back
- optional - short glass pack or resonator near back bumper to quiet everything down.
If you want to keep your present 2.5" exhaust (not recommended based on track times), get a 2"X2.5" Y-pipe at same position and run 2" pipes from headers to Y.
My question is in regards to the BOLD quote. Does Flowmaster make what I need? Also is there a part# you could provide.
I doing this one exactly as you have outlined this time. I hope I will be able to hear myself thing when driving. :wink:
Clifford shorty headers- Ordered
Y-Pipe - Planning on this one. http://tinyurl.com/2ca25c Your approval is required.
Muffler 3" by 3" offset/offset OR
Muffler 3" by 2.5" offset/offset. Will there be a huge difference in power between the two and what about noise? Part# or link? I really hate the DynoMax muffler I now have which is a 3"x3" super turbo flow. http://tinyurl.com/2ogepq It drones badly. Maybe with the new design it would be different. I'd like to try Flowmaster or MagnaFlow this time.
I also plan to install 2 cuts outs just before the muffler, so I would really like to keep the tailpipe at 2.5" http://tinyurl.com/23s3y6 I only need to buy one more, as I already have the other one installed.
Resonator 2 1/2 to be installed along gas tank. http://tinyurl.com/2estv3 Something like what is shown. Other suggestions?
Chrome tip- http://tinyurl.com/yo8pyg OR http://tinyurl.com/2zo3gc like this but in the 2.5 inlet and 3" outlet angle tip
Keep in mind that the exhaust shop that I plan to use can't make the bend needed to run a 3" tailpipe over the axle.
Basicly I am leaving this one in "your" hands.
You design it - I will build it.
Thanks in advance.
PostPosted: Fri Feb 01, 2008 6:17 am
Bren,
Happy to help, and I hope this gets you some solid gains. It should!
That is the correct Y-pipe, same as on my car.
Hmm, I have the 3-chamber 3"X3" Flowmaster on my car and feel it's too loud/drony. Thought the Dynomax would be better. I just put a resonator like that on my car and it helped. If you want quieter, the Thrush turbo should be quieter than either DMx or FLMstr muffs. 2.5" tail should be just fine. I have a Magnaflow on my Valiant, which sounds awesome, but it is a short exh system racecar, so noise not so important. Might be worth a try. Cameron Tilley likes Hooker Aerochambers, but noise not an issue for him either.
Why 2 cutouts before the muffler? Two inline in the straight section? I guess this would allow some exhaust tuning at the track...? Remember, the Y-pipe should join just behind the trans X-member, maybe put the actual Y junction 2-4" behind the X.
Happy bending,
PostPosted: Fri Feb 01, 2008 6:22 am
That Flowmaster Y is a nice piece. I have put 50,000 miles on one in my work truck.
I use the 2.25 to 3" Y .....then to a Flowmaster 50 http://store.summitracing.com/partdetai ... toview=sku
The flowmaster 50 is much quieter than a 40.....mine is at least 30,000 miles old and is still fine. You wont need a resonator with this muffler.
PostPosted: Fri Feb 01, 2008 6:37 am
Happy bending,
Image Your right I just need a 3"cutout
PostPosted: Fri Feb 01, 2008 9:21 am
I am looking at these Flowmaster mufflers, all in the 3" offset / offset
http://www.flowmastermufflers.com/40_delta.html 40 delta flow
http://www.flowmastermufflers.com/40_super.html Super 40
http://www.flowmastermufflers.com/50_delta.html 50 Delta Flow (not sure if it will fit yet)
I am really looking for low interior noise.
PostPosted: Fri Feb 01, 2008 10:00 am
I have the 50/Delta on my 64. Yours will be quieter since I have no backseat.
PostPosted: Fri Feb 01, 2008 12:24 pm
Are you also saying that if the 50/Delta fits your car, it will fit mine? Is your muffler mounted in the stock location? Is your part number 943053? http://tinyurl.com/2pcykf
PostPosted: Fri Feb 01, 2008 1:01 pm
I guess if its to loud I can add the resonator later.
PostPosted: Sat Feb 02, 2008 4:16 am
Bumping this question as I don't know the differences between a 64 and a 67s underside.
PostPosted: Sat Feb 02, 2008 8:46 am
Should be same 64 - 67 in that region. Can't remember part number, but that pic looks longer than mine. They angled mine upward somewhat into the axle well cutout, but it does fit and doesn't hang low.
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 4 guests
