It is currently Tue Jun 23, 2026 4:06 am
 Post subject: Motor Mounts
PostPosted: Fri Feb 01, 2008 7:09 pm
trying to find motor mounts for my project. Doug built a motor for it,The Guzzi motor,going in a 62 chop top Valiant,need motor mounts for 62,-65 ,Auto zone a no go,Pep boys,no,Napa,No,Haps auto parts,no.Curtis Cristianson auto parts ,no.Hal John auto parts,no Kragen,no,wondering where to find a YES, Thanks Mark
PostPosted: Fri Feb 01, 2008 7:13 pm
have you tried www.rockauto.com ?
PostPosted: Fri Feb 01, 2008 7:19 pm
I think Dan said Imperial services was coming out with poly mounts. Try them.
I know www.motormountz.com has "stock" type..
PostPosted: Fri Feb 01, 2008 7:20 pm
If that fails, Damper Doctors rebuild motor mounts as well:
http://www.damperdoctor.com/Merchant2/m ... y_Code=MOT
obliquely-inclined state of mind
PostPosted: Fri Feb 01, 2008 7:22 pm
That was less than 5 min,I am even more impressed with this list now,THANK YOU,Mark
PostPosted: Fri Feb 01, 2008 7:36 pm
I just went to motormountz.com. Their site is not quite complete. Use there part numbers. Have to look up for 66 dart.
EM2303 for left
EM2304 for right
EM2272 for trans.
I have gotten 3 sets from them. Good service.
PostPosted: Fri Feb 01, 2008 7:50 pm
Thank you,I searched and didnt come up with anything,I am assumeing 66 and earlier are all the same?,did come up with 170 mounts but they didnt list r and l,are 170 mounts different? curious now,Mark
PostPosted: Fri Feb 01, 2008 7:59 pm
More searching,same for both motors,your numbers helped me a bunch will be ordering tommorrow,Thanks Again,Mark
 Post subject: Motor mounts
PostPosted: Thu Oct 09, 2008 10:24 pm
I'm looking for motor (225) and tranny (904) insulators for my '67 A-body. I just checked out www.motormountz.com and their prices seem too good to be true. Does anybody know where these mounts are made? I've heard the ones from India and China should be avoided because of poor quality. Are there any places that have quality mounts? Thanks for any help.
Roger
 Post subject: Re: Motor mounts
PostPosted: Fri Oct 10, 2008 5:14 am
Roger
I have two sets on the shelf. One set made in Mexico, and one set made in India. I have a set of their mounts in my Valiant and Barracuda race cars, for a couple of years, now, with no problems.
PostPosted: Fri Oct 10, 2008 6:43 am
I called Imperial Services last week and their answer on the polyurethane safety-lock mounts for '62-'66 slant-6 A-bodies (all the same left and all the same right) was "a couple of weeks from now" again :-( :roll: I'm sure they'll be out eventually, but even I — knowing firsthand how product development can drag out for ages — am getting itchy for a set of those mounts!
The only mounts left in general stock are 3rd-world items made of poor-quality materials, but they're better than nothing, at least temporarily.
Interesting that Damper Doctors rebuild mounts, didn't know that.
The situation is better for the '67-'72 A-body slant-6s; the 3rd-world types are out there but you can also get a very good polyurethane left-side mount from polybushings.com . You're on your own for the right-side mount for now, but one good mount (especially on the oily side, the left) with one 3rd-worlder is better than a pair of 3rd-worlders.
The '62-'72 rear (transmission) mounts are all alike with one minor exception: Through '65 they have two bottom studs into the crossmember, '66-up they have only one. You can use the 1-stud mount in any '62-'72 A-body, but the 2-stud mount only fits crossmembers with two drilled holes. You can get nice polyurethane versions of both types (with immediate availability) at Imperial Services.
The other alternative to 3rd-world mounts is buying 1st-world New Old Replacement Stock mounts from one of the many vendors of such parts. Old Car Parts Northwest has a fair stash of the '62-'66 mounts, the '67-'72 mounts, the rear mounts, and a couple months ago when I was there I counted at least half a dozen of the extremely robust '60-'61 Valiant/Lancer "vertical shear" type mounts, which seem never to wear out. The left vertical shear mount would require welding a tab w/bolt hole to the mount "foot" or to the K-frame if you wanted to use it in a '62-'66 car, but it'd still be a relatively easy and "right now" way to have a sturdier engine mount in a built-up '62-'66 application.
(And since I brought up Polybushings, I did call Johnny over there last week, as well — he's working on our polyurethane spools for the '73+ mounts, and seemed in principle interested in working on some kind of extra-rugged mounts for the '62-'72 cars, either a spool-mount retrofit or a vertical-shear arrangement, perhaps. We both agreed it's best to get the '73+ spools done first, though!)
PostPosted: Fri Oct 10, 2008 11:11 pm
Dan if the ploy mounts go through for the 73 up please pm me I would really like a set.
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
PostPosted: Fri Oct 10, 2008 11:14 pm
just get out the mig n the torch and reinforce them :?: simple task really
87 d150 2bbl carb 225
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
89 f450 diseal 4x4 dually 5sp
Users browsing this forum: Google [Bot] and 7 guests
