It is currently Mon Nov 23, 2026 12:48 pm
 Post subject: Identify crank
PostPosted: Thu Feb 07, 2008 1:55 pm
What 225 engines came with forged crank? Is there a way to identify using serial number on the block or what? This is a 74´ dodge dart 4d.
Thanks
Rob,
Dart -74 4dht.
PostPosted: Thu Feb 07, 2008 2:05 pm
Cast cranks started about '77, according to THIS
PostPosted: Thu Feb 07, 2008 2:06 pm
A 1974 SL6 would be a forged steel crank engine,
The large "casted-in" number on the driver's side of the engine block should be 2806830-xx (the xx can be any number from 1 to 24?)
PostPosted: Thu Feb 07, 2008 2:25 pm
Almost right, but not quite. Midyear '76 was the changeover.
PostPosted: Thu Feb 07, 2008 3:24 pm
Pulled crank tap on them (on the counterweight) lightly with brass hammer:
bell-like ring: forged
CLUNK!: cast.
Cheers, Wizard
 Post subject: Scrape the tag...
PostPosted: Thu Feb 07, 2008 3:28 pm
The pad on the passenger side of the engine above spark plug #1 where the head meets the block will have a set of numbers if '225E' then is cast...
It's kind of weird but of all the '76 A and F bodies of that year I've seen or torn down those with their numbers matching engine all the F-bodies got cast crank engines (except a couple of coupes I came upon with early date codes on the tag)... all the A-bodies seem to have forged crank units (would love to see a 1976 4 door valiant with a cast crank engine as OEM to verify who got 'what')...
-D.idiot
