It is currently Mon Nov 23, 2026 2:28 am
 Post subject: EGR valve bypass
PostPosted: Sun Feb 10, 2008 5:35 pm
When you bypass the egr valve do you just plug the ends the hoses come from and remove the egr?
Ronnie
http://www.cardomain.com/ride/2714941
 Post subject: Egr
PostPosted: Sun Feb 10, 2008 6:03 pm
Yes, and leave the EGR there, or buy the block off plate and gasket. I paid less than #10.00 for both.
EGR block off plate from the dealer # 3671447 lists for $5 Dealer item, p/n 3671 447, used with standard EGR valve gasket p/n 4173 167.
Last edited by Aggressive Ted on Sun Feb 10, 2008 6:16 pm, edited 2 times in total.
PostPosted: Sun Feb 10, 2008 6:07 pm
Proceed carefully. Pull the hose off the EGR valve and plug the hose securely, then drive the car around to see if you get a pinging problem, before you more permanently eliminate the EGR.
Users browsing this forum: Bing [Bot] and 14 guests
