It is currently Sat Oct 24, 2026 7:43 am
 Post subject: Motor Mount Bolt Problem
PostPosted: Mon Oct 07, 2002 3:28 pm
Anyone have a problem with the motor mount bolt comming loose? This is the 1/2" nut with affixed cupped washer that holds the mount to the K Frame. Twice I've had the LH one come loose and once on the RH side. New mounts torked to spec both times. Any suggestions?
usclstaffingnet@sprintmail.com
PostPosted: Mon Oct 07, 2002 7:40 pm
: Anyone have a problem with the motor mount bolt
: comming loose? This is the 1/2" nut
: with affixed cupped washer that holds the
: mount to the K Frame. Twice I've had the LH
: one come loose and once on the RH side. New
: mounts torked to spec both times. Any
: suggestions?
Get a nut with a nylon lock.
lancer_41@excite.com
PostPosted: Tue Oct 08, 2002 9:00 am
: suggestions?
I never had this problem, It could be that the threads are worn, you my want to try som different nuts with some lock-tight.
