It is currently Mon Oct 26, 2026 3:23 am
 Post subject: Slant Six Knock?
PostPosted: Tue Oct 08, 2002 10:03 am
I can hear a slight knock in my engine. One person said its the typical "Slant Six Knock" Is there such thing as normal knocking in the slant six?
If you had a knock in your engine what would be your first steps in trying to fix it? Where would you go first?
Thanks for any help!
Bolt
 Post subject: Re: Slant Six Knock?
PostPosted: Tue Oct 08, 2002 10:55 am
: I can hear a slight knock in my engine. One
: person said its the typical "Slant Six
: Knock" Is there such thing as normal
: knocking in the slant six?
: If you had a knock in your engine what would be
: your first steps in trying to fix it? Where
: would you go first?
: Thanks for any help!
: Bolt
I don't know what a 'typical' slant six knock is, although I've had a couple that did knock. I had one that the PO had run out of oil on the freeway and driven for who knows how many miles. That one was fatal. I had another that knocked on start-up for almost 10 years before it died.
What can you do? You could try replacing the bearings in the engine while it's still in the car. Or just try different weights of oil, maybe that would quiet it down.
fglmopar@aol.com
PostPosted: Tue Oct 08, 2002 12:52 pm
: Bolt
"Common" SL6 engine noise can be from the mechanical lifters, the con rod bearings or from piston "fit". In some cases a wrist pin (piston pin) can contribute to piston noise.
Adjust valves if it is a "ticking" noise, but there should always be a little noise from the lifter when adjusted correctly.
For the other noises, thicker oil or an engine rebuild are the solutions.
PostPosted: Tue Oct 08, 2002 8:34 pm
One quick help for a nosiy engine is 4 QT's of sae30 and a qt. OF LUCAS oil stabilizer.
Trysix
soupitup@msn.com
PostPosted: Wed Oct 09, 2002 11:44 am
It could be your fuel pump making noise. I replaced my old one thinking it was going out, now the new one does the same thing.
: Bolt
ecwfury@msn.com
PostPosted: Wed Oct 09, 2002 2:30 pm
: It could be your fuel pump making noise. I
: replaced my old one thinking it was going
: out, now the new one does the same thing.
That is worth checking out. I did see some very small metal fragments in the fuel filter.
PostPosted: Thu Oct 10, 2002 12:22 am
I had a knock, took it to a shop, they wanted to replace the motor. I used a piece of heater hose as a stethoscope to locate the noise. It was actually the clutch. You usually don't have a bearing problem if the oil pressure is normal.
: Bolt
PostPosted: Fri Oct 11, 2002 1:49 pm
My fuel pump makes the same low thud knocking noise.
ldhal@granitecity.com
PostPosted: Sat Nov 09, 2002 3:50 pm
like dartster69 mine has an intermittant fuel pump knock that when I first heard it , I thought my engine was toast. bother's me enough that I'm going with an electric pump.
PostPosted: Sat Nov 09, 2002 3:58 pm
Every Slant I own has a knocking sound in it. The original motor in my Duster rattled just above idle the whole time I had it (4 years) and nothing ever fell out.:) Slantzilla makes all kinds of rattles and hammers, but so far nothing has exited either.:D
Users browsing this forum: mr.norm and 8 guests
