It is currently Sun Nov 22, 2026 11:43 am
 Post subject: Spark Plugs?
PostPosted: Wed Feb 13, 2008 5:45 pm
Which ones should I use? I heard the NGKs are good, but which one exactly? Its on a 1975.
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Wed Feb 13, 2008 6:06 pm
I like NGK spark plugs a lot. The '75-up cars take a different type of spark plug than the '74 and earlier cars. Stock plug for your '75 is a # UR4. You can try going a step colder with today's cleaner-burning gasoline, to gain some ping-resistance (UR5). If you want to spend money on ultrapremium spark plugs that'll last a very long time and allow the use of a wider plug gap for better idling and driveability, it'll be a UR4IX or UR5IX. I'd recommend buying the regular plugs for now, until you figure out which heat range works best for your setup.
PostPosted: Wed Feb 13, 2008 6:18 pm
I run UR4's in my 1978 head and they are very,very nice! They are the best plugs I have ever used. :D
Last edited by Aggressive Ted on Wed Feb 13, 2008 6:32 pm, edited 1 time in total.
PostPosted: Wed Feb 13, 2008 6:20 pm
I'm using UR4 in my stock 1979 D-100 225 and they're working well.
PostPosted: Wed Feb 13, 2008 6:23 pm
Ive read on other posts about the ngk plugs but it was on a '74, will the plug wires mentioned for a '74 work on a '75?
Ronnie
 Post subject: Yep..
PostPosted: Wed Feb 13, 2008 6:32 pm
That's affirm...
Users browsing this forum: Google [Bot] and 18 guests
