It is currently Thu Jun 18, 2026 7:12 pm
PostPosted: Sun Feb 10, 2008 3:35 pm
Thanks for the replies......and thanks for the part # Ted. :)
O.K. I'm slower than a stock engine. :roll: I may have to go ahead with a converter and gears sooner than I thought. The cam too......it makes sense: If that cam gear is mis-marked, it could be anywhere. If it's retarded, I'm losing what cylinder pressure I have left at low RPM.
I guess a Midwest 3000 converter is calling my name too. :D
(Hey 'Zilla, if we're ever at a race together......I would be honored to ride in that car. :D :D It has to feel good to go that fast with a slant... :lol: )
Thanks again!
Are you looking for an early or late converter?
http://www.slantsix.org/forum/viewtopic.php?t=27111
PostPosted: Sun Feb 10, 2008 5:47 pm
Hey Bren,
Yep, I need the large style ('72 crank & tranny).
That is a loose converter......maybe it would stall a little less on my engine? Let me know if it's still available, and I'll shoot you a PM.
I once had a Poly 318 (not a slant, but just as unique), with a Carter BBD on it, all factory. It would run 0-60 pretty quick...., and the '62 B-body power drum brakes worked great. :wink:
Anyway, back on topic...good luck on the car, 'Zilla! Hope to race some of you folks in the near future... :D :D
Thanks again!
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Mon Feb 11, 2008 11:23 am
...Cam timing and/or ign timing is likely your current big problems.
I have the exact same thinking... I bet that cam is way off centerline.
What is the total spark advance? Too much total advance makes a SL6 run "flat".
You can do some checking and testing.
It is pretty easy to check total advance with a timing light.
Slants like a lot of initial (10 to 12 degrees) and about 30 degrees total, this is hard to get without recurving a distributor.
Adjust the valves and loosen the exhaust lash as much as possible with-out ticking, this will help cylinder pressure.
PostPosted: Mon Feb 11, 2008 11:53 am
Last Sept. I took my '68 Dart to the 1/8 mile track to the "testNtune". I made dozens of passes for the hell of it, all of them were in the low 12's at 58 mph. Best was 12.092 @ 58.36mph. She was totally stock at the time. I didn't bring anything along to "test" but for the heck of it I checked the timing... the total was 40 degrees :shock: . But since it runs good and gets 22 mpg, I just left it alone.
The best thing about racing a slow car is not only the sensation of a 9 sec. car blazing by you, but the fact that by the time you get past the scoreboards you can see your ET and MPH!
Chris'
Autobody
Restoration
Service
PostPosted: Mon Feb 11, 2008 12:01 pm
I bet if you would have adjusted your timing to something less the 40 total and made additional passes, the MPH would have increased.
I tend to run more the 30 total on the street cars, doing that gives better off-idle "feel" and mpg.
I knock the timing back if I do a lot of high speed driving or at the drag strip. (WOT)
PostPosted: Mon Feb 11, 2008 6:35 pm
Thanks, Doc! Yeah, Lou gave me some pointers on the car......I really need to degree the cam.
The total advance (Minus Vac.)is probably pretty close to 32* or so. My governor slot is ~.385. (It's pretty short :shock: ) It 'feels' much better with the shorter-slot....I installed a heavy long-loop spring, and a mopar light spring. It's all in by 2400 or so, the last few degrees come in s-l-o-w.
Initial is 14* now
It's looking more and more like my cam is out of line. :?
I am running looser lash......my cam called for .014/.014, and I'm running .016/.016. I am tempted to run it .020/.020
I'm kinda scared to loosen it too much.....it's a pretty steep ramp, and I would hate to bite a lifter. How do you know when to stop? (What kind of 'tick' are we talking about?....just short of a tap?) :?:
Thanks
PostPosted: Tue Feb 12, 2008 6:55 am
'68 V200, 225, untouched motor with 2.25" exh and 30* timing running on 13" Sears tires installed in 1976
0-60 - 11.7
What kind of cranking compression do you have?
Slant Cecil
PostPosted: Tue Feb 12, 2008 7:04 am
Cecil,
What rear end gears does your 68 V200 have?
PostPosted: Fri Feb 15, 2008 8:47 pm
Update:
Moved initial timing to 10*, and time improved to 10 seconds!! :D
MPG dropped to 18, but it has alot more pep now. The cam is next... :twisted:
PostPosted: Sat Feb 16, 2008 5:03 am
Great! Moral of the story - buy a dialback timing light and spend some time on your dist curve... What is your total mech advance now?
Users browsing this forum: Google [Bot] and 8 guests
