It is currently Thu Oct 22, 2026 10:09 am
PostPosted: Sun Oct 13, 2002 5:52 pm
I will try my question again, I didn't get an answer last time, but I think someone out there must know the answer.
I am confused about the bi-metal spring that opens and closes the heat damper on my exaust manifold. I got it back from the machine shop and it is not how it was when it went in. The outside of the spring is not attached to anything, and I can't figure out how it is supposed to attach.
Can someone help me?
Thanks
Bob
lasergame@prodigy.net
PostPosted: Sun Oct 13, 2002 7:21 pm
It doesn't attach to anything; it just hooks over the pin.
lancer_41@excite.com
PostPosted: Sun Oct 13, 2002 7:30 pm
: It doesn't attach to anything; it just hooks
: over the pin.
Do I adjust the screw to make it reach the pin? If I pull on it, it snaps back. Sorry for my rookie question.
PostPosted: Sun Oct 13, 2002 8:03 pm
: I will try my question again, I didn't get an
: answer last time, but I think someone out
: there must know the answer.
: I am confused about the bi-metal spring that
: opens and closes the heat damper on my
: exaust manifold. I got it back from the
: machine shop and it is not how it was when
: it went in. The outside of the spring is not
: attached to anything, and I can't figure out
: how it is supposed to attach.
Sounds like you need to "wind" the spring another 1/2 turn or so and slip it back under the pin.
If all is correct, doing this will put enough force on the flap to close it. Once the spring heats-up, it looses tension and lets the flap open.
PostPosted: Sun Oct 13, 2002 8:16 pm
: Sounds like you need to "wind" the
: spring another 1/2 turn or so and slip it
: back under the pin.
: If all is correct, doing this will put enough
: force on the flap to close it. Once the
: spring heats-up, it looses tension and lets
: the flap open.
: DD
I had to bend the end of the spring slightly, only then would it hold a shape to stay on the pin. It was an easy fix, once I came to grips with bending the spring.
Thanks.
PostPosted: Mon Oct 14, 2002 11:37 pm
There should be a "hook" on the end of the spring that wraps around a post sticking out of the manifold, if I recall correctly. See if you can find another car to look at.
Chuck
: Can someone help me?
: Thanks
: Bob
sl6@omnipages.com
PostPosted: Tue Oct 15, 2002 7:17 am
: There should be a "hook" on the end
: of the spring that wraps around a post
: sticking out of the manifold, if I recall
: correctly. See if you can find another car
: to look at.
: Chuck
Thanks Chuck, with a little bending of the end of the spring I got it to rest on the pin the way it should. Seemed too easy to think that's all that had to be done.
PS-Did you get my donation for the website?
PostPosted: Tue Oct 15, 2002 7:41 am
Yup, I got it. Thanks! You are considered a "sponsor" now!
Chuck
: Thanks Chuck, with a little bending of the end
: of the spring I got it to rest on the pin
: the way it should. Seemed too easy to think
: that's all that had to be done.
: PS-Did you get my donation for the website?
sl6@omnipages.com
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 19 guests
