It is currently Thu May 28, 2026 6:01 am
 Post subject: 63 Dart Fuse Block
PostPosted: Mon Feb 11, 2008 8:03 pm
When someone (me) painted the dash in my Dart, they got overspray on the fuse block, so I can't really make out what the words are. I can sort of see some, but not all. Is there anyone who knows or can find what the words are supposed to be?
Also, Where is the fuse block supposed to be attached? Mine is just kind of hanging.
Thanks.
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Mon Feb 11, 2008 8:18 pm
On my 64, the fuse block is near the steering column and attached to the lower painted steel panel with a big screw that goes up into the fuse block (the screw taps into the fuse block).
Look for a hole in the steel panel and trial fit some screws into the fuse block until you find one that works
PostPosted: Mon Feb 11, 2008 10:49 pm
Thanks, I saw a threded hole on the fuse box. Any idea on what the words are?
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Mon Feb 11, 2008 10:57 pm
I just went with the position of the fuse and the wiring diagram.......
PostPosted: Tue Feb 12, 2008 7:24 am
I don't know what kind of paint you used but try running a soft clean rag over fuse block with laquer thinner.Don't scrub it,just go over it quick and light.Make sure the battery is disconnected,don't want no flames an such on the new paint :wink:
PostPosted: Fri Feb 22, 2008 3:48 pm
Site Admin
From left to right:
Instrument
Tail/Stop/Dome
Cigar
Accessories
Heat/AC
Radio
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Sat Feb 23, 2008 12:33 am
Thanks Chuck, that's what I needed.
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Sat Feb 23, 2008 1:39 pm
Site Admin
Did you find the mounting tab, or do I need to round up a picture for you?
PostPosted: Sat Feb 23, 2008 6:59 pm
Is it on the bottom of the dash? There's some kind of tab there. It looks like it would bolt right up.
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Sat Feb 23, 2008 11:23 pm
Site Admin
That's it. I can't remember what the screw looks like, but it has to be fairly long.
