It is currently Fri Nov 20, 2026 5:16 am
 Post subject: Carb question.
PostPosted: Sat Feb 23, 2008 6:56 pm
My car is running too rich at idle. Which screw is for the idle mixture?
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Sat Feb 23, 2008 6:58 pm
Bottom one.
PostPosted: Sat Feb 23, 2008 8:13 pm
generally speaking, idle screw are brass and have a coil spring between carb base and screw head. Also, the head tends to be knurled.
Juan Ignacio Caino
PostPosted: Sat Feb 23, 2008 8:23 pm
What kind of carb is it?
PostPosted: Sat Feb 23, 2008 9:31 pm
Stock 1 barrel. That's the screw I thought it was. Do I turn it out or in to lean it out?
1970 Nova 12.53@108
1970 Bug 15.38@87
 Post subject: In
PostPosted: Sat Feb 23, 2008 10:58 pm
In(clockwise) to cut off the fuel to te idle circuit... (the only 'out' is on mid 70's to 80's reverse idle screw Holley carbs found on smog bogger V-8's...)
PostPosted: Sun Feb 24, 2008 4:11 am
What you want to do is turn it until it smooths out and idles the fastest. This could be in or out that it needs. You might want to make sure your choke is not trying to stay closed on you and that you have no vacuum leaks. Also make the ajustment with the engine hot.
What makes you think it rich ?
Jess
PostPosted: Sun Feb 24, 2008 10:36 am
Thanks guys. I think its too rich because I had it idling on a trailer, and afterwards, the trailer right behind the exhaust was real black.
1970 Nova 12.53@108
1970 Bug 15.38@87
Users browsing this forum: Bing [Bot] and 8 guests
