It is currently Tue Jun 16, 2026 8:46 pm
 Post subject: Shock mounts revisited
PostPosted: Tue Feb 26, 2008 3:06 pm
Ok, so I found a fellow locally who has a pair of shock mount studs that are the right size for my application. I'm going to pick them up tonight. The plan is to cut off the existing studs, drill a hole in the right spot and bolt them in. Is this the right way to do it or do I need to have the studs welded in place? Welding is something I can't do, so if I can get away with simply bolting them in I'm golden.
Thanks in advance,
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Tue Feb 26, 2008 3:35 pm
Bolt. It will be easier next time.
PostPosted: Tue Feb 26, 2008 6:15 pm
Outstanding! Thank you sir.
PostPosted: Wed Feb 27, 2008 6:47 am
If you can drill the hole, by all means bolt them in. :D
PostPosted: Wed Feb 27, 2008 7:41 am
A drill I can work. A welder..... Let's just say I've welded once and I managed to flash myself twice. :oops:
Nat
PostPosted: Wed Feb 27, 2008 8:11 am
Best to keep your pants on while weldink......
PostPosted: Wed Feb 27, 2008 8:17 am
Where's the fun in that?
PostPosted: Wed Feb 27, 2008 9:07 am
Hey now! This is a family joint here. None of that kinda talk mister. :shock:
PostPosted: Wed Feb 27, 2008 11:10 am
Hey, if I didn't flash myself, I'd NEVER get flashed. :(
vm
