It is currently Sun Jun 21, 2026 9:05 am
PostPosted: Mon Feb 25, 2008 8:45 am
Hey guys. I just put everything back together on the 225 and I started having compression issues after tightening down the valves. I re-adjusted them one cylinder at a time and restarted it and it sounded great for a car that I havent rebuilt yet. Now Im having an issue with it running for about 5 minutes and then it sounding like its flooding out and then dies. Im wondering if maybe it is and Im not sure if its the carb or the intake valve opening to fast. This is my first time with valves. So I guess you can say Im a virgin to it and the advice so far on here has worked, so Im asking for more advice.
Thanks
Josh
PostPosted: Mon Feb 25, 2008 11:12 am
Did you adjust the valves with the engine running?
Here is the valve adjustment procedure if you don’t have it:
http://tinyurl.com/2p4jvm
Danny
PostPosted: Wed Feb 27, 2008 10:53 am
no i didnt i figured it would be difficult and i wouldnt know how if it was possible.
PostPosted: Wed Feb 27, 2008 11:37 am
You have to adjust them hot and most everyone says you have to do it with the engine running.
If you did it without the engine running, you have to turn the engine to get each cylinder at TDC before adjusting. If you adjusted them all at one time, without turning the engine, you have a some that are way too tight and some way too loose. Some may hardly open and others may never close.
That would definitely be the biggest part of your problem.
Follow that link above and it’ll tell you step by step how to do it.
Danny
PostPosted: Wed Feb 27, 2008 4:50 pm
i wanna see someone check clearance while runnin. if ur quick, ha
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Thu Feb 28, 2008 6:15 am
I have only adjusted once or twice with engine running, and I have probably adjusted Slant valves about 300-500 times, no joke. It is not necessary. IT IS necessary to do it with the engine hot (run for at least 10-15 min). It sounds like your valves are too tight.
