It is currently Sat Oct 24, 2026 7:39 am
 Post subject: Modifying for EFI, HELP!
PostPosted: Thu Oct 24, 2002 5:18 am
I read the great article on EFI but need more info on modifying the stock intake. Any one have any PICS or tips?
slantedsix225@aol.com
PostPosted: Thu Oct 24, 2002 6:56 am
: I read the great article on EFI but need more
: info on modifying the stock intake. Any one
: have any PICS or tips?
I'm in work on a conversion, and am done modifying an aftermarket intake. I had to fabricate a fixture in order to "drill" the holes in the manifold runners. It's available to borrow, but it's kinda heavy, so shipping will be a bit pricey. Where are you located?
Roger
GTS225@aol.com
PostPosted: Thu Oct 24, 2002 8:35 am
Have you looked at Doc's article on modifying the stock manifold in articles? He's got some pics.
I've got a few pics on my site as well if you haven't seen them already . . .
http://www.mopars.org/tools/bigred/efi.html
ahtoews@shaw.ca
PostPosted: Fri Oct 25, 2002 4:46 am
: I'm in work on a conversion, and am done
: modifying an aftermarket intake. I had to
: fabricate a fixture in order to
: "drill" the holes in the manifold
: runners. It's available to borrow, but it's
: kinda heavy, so shipping will be a bit
: pricey. Where are you located?
: Roger
Thanks Roger, I'm in Pittsburgh.
I'm not sure yet, but I thought about it and most likely send it to a local shop for drilling. I'll keep your offer in mind.
Thanks, Dan M.
PostPosted: Fri Oct 25, 2002 6:10 am
: Thanks Roger, I'm in Pittsburgh.
: I'm not sure yet, but I thought about it and
: most likely send it to a local shop for
: drilling. I'll keep your offer in mind.
: Thanks, Dan M.
OK, Dan....your call. It wold have to come from Iowa.
It's just that I'm kind of a cheapskate, and when local shops started talking $120-$130 for poking six holes in my manifold, I thought it was a bit much.
I ended up welding a piece of angle iron to some flat stock, "legs down", so that I could mount an intake to one of the "legs", (now at 45* to the flat stock. That way I could clamp it onto a drill press table and "drill" the holes with a .75" carbide burr.
Roger
GTS225@aol.com
Users browsing this forum: Amazon [Bot] and 8 guests
