It is currently Sat Nov 21, 2026 1:55 am
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3
 Post subject: ram air
PostPosted: Sun Mar 02, 2008 7:26 am
i don`t understand why so many think ram air is not effective, all normally asperated cars will benefit from a forward facing inlet that creates pressure, on my 75 duster i had a snorkel scoop 6in high and i had 2inlbs pressure at 90mph at manifold when i sealed it to the carb, bren if you have header now your slower performace is most likely jetting, headers will effect your jetting , usually making it leaner, also you have to check pressure at the manifold and make sure it dozen effect your power valve. :?
PostPosted: Mon Mar 03, 2008 4:56 am
sweet, i'm inspired to finish my cold air i have a snorkel hoodscoop on my duster should be easy to do
Thanks, Kev
PostPosted: Mon Mar 03, 2008 9:59 am
Hooked up mine a month ago and it runs much smoother and has allot more power.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
