It is currently Fri Nov 20, 2026 11:31 pm
 Post subject: Oil pan gasket
PostPosted: Sun Mar 02, 2008 8:38 pm
I removed my oil pan today, and the gaskets were all rubber. Then I opened my Felpro oil pan gasket set OS 12705 C-1, and the rail gaskets were cork.
Would all rubber be better? Does anybody know who makes an all rubber set? Should I even worry about it?
PostPosted: Sun Mar 02, 2008 9:45 pm
RDJ,I wouldn't sweat it,used felpro on my build and have had no problems.I used some permatex goop on the pan side as I figured that would be less straight/flat and maybe more prone to leaking.
PostPosted: Mon Mar 03, 2008 6:39 am
RDJ
Both are available and either will work. I used a skim coat of permatex 2 on my cork gaskets and havent had any trouble been doing that for years.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Mar 03, 2008 6:40 am
Biggest trick is to get the pan as flat as possible and don't overtighten the bolts to cut the gasket. :D
PostPosted: Mon Mar 03, 2008 7:30 am
Thanks guys!
