It is currently Sat Oct 24, 2026 5:36 am
 Post subject: carb blowback
PostPosted: Thu Oct 31, 2002 3:28 pm
My /6 is a hard cold starter. Often before it starts it will "diesel" and blow smoke and stuff back through the carb. I think it actually might be turning backwards when this happens. It WILL eventually start, but always takes a while, I usually have to manually open the choke, an I sometimes run through a battery first.
I've got plenty of fuel at the carb, and the spark seems strong at the distributor, and at every plug I check. It runs great when it starts, and hot starts are very easy, if I don't give it too much gas. I'm out of ideas....
zac
zac_smith@hotmail.com
 Post subject: Re: carb blowback
PostPosted: Thu Oct 31, 2002 7:10 pm
: My /6 is a hard cold starter. Often before it
: starts it will "diesel" and blow
: smoke and stuff back through the carb. I
: think it actually might be turning backwards
: when this happens. It WILL eventually start,
: but always takes a while, I usually have to
: manually open the choke, an I sometimes run
: through a battery first.
: I've got plenty of fuel at the carb, and the
: spark seems strong at the distributor, and
: at every plug I check. It runs great when it
: starts, and hot starts are very easy, if I
: don't give it too much gas. I'm out of
: ideas....
: zac
Your valves may be sticking when cold. Try putting some Maevel Mystery Oil in the crankcase and see if that helps. Works great on sticky valves.
Chuck
sl6@omnipages.com
Users browsing this forum: No registered users and 20 guests
