It is currently Tue Jun 23, 2026 1:52 am
Post new topic  Reply to topic  [ 102 posts ]  Go to page Previous 1 2 3 4 5 6 7 Next
PostPosted: Sun Mar 09, 2008 9:25 am
Going to pick a part to get trans tube,trany line fitting,then will be wireing and running fuel lines,intall tank,relocate battery and VROOM,hopefully,tomorrow,Mark
PostPosted: Sun Mar 09, 2008 9:29 am
Wow: thanks so much for the "step-by-step" thread, Doc! Really great to have all that info centralized in one place!
obliquely-inclined state of mind
PostPosted: Sun Mar 09, 2008 10:06 am
We have to thank BC Sandy for the locked thread, step-by-step format.
I think that approach makes it harder for members to comment but it sure does keep the build thread itself clear and concise, with-out a lot of 'side discussions' like we saw in the Twiggy thread.
 Post subject: weather
PostPosted: Sun Mar 09, 2008 11:34 am
sandy 4000km away and we have your weather now, in the garage with cotton glove on setting up the new blower drive belt and new base pan. :wink:
 Post subject: cam
PostPosted: Sun Mar 09, 2008 12:10 pm
doug the cam you picked was it reversed ground to those spec. to take advantage of the firing cycle that was in another tread? i was trying to go back to the street combo i ran 19yrs ago, it was a .030 over/ stock vavle 3 angle/ 9.5/1comp / .490lift, 270degs m.p. cam, i liked the performance it gave until i got my first oil gear failure, with help from sandy i am trying to get a comp reverse cam, 282deg/495lift/int and 270degs/468lift ex/110deg lobe sep. i am hoping this cam will be as good or better as the m.p. cam when i get the street car back on all four`s :!:
Last edited by terrylittlejohn on Mon Mar 10, 2008 6:01 am, edited 1 time in total.
PostPosted: Sun Mar 09, 2008 9:22 pm
I am real interested in how this cam performs.
My guess is that is will be a little top end limited but it does have a good amount of lift on the intake valve... and I will use some 1.6 rocker arms to give it a little more.
A few more days and we will have a general idea on how this combo works.
PostPosted: Mon Mar 10, 2008 4:12 am
Where do you get those JP gear & chain sets?
Jess
PostPosted: Mon Mar 10, 2008 9:15 am
I purchase my sets directly from the land of Oz... Australia.
Cox Bros were (are?) a US distributor as well as a few others.
PostPosted: Mon Mar 10, 2008 6:00 pm
After mounting the parts, spinning the crank, finding where stuff hits, take it apart and grind, re-install the parts... repeat as needed, (about a dozen times) the assembly is ready for the oil pan installation. We will leave the oil pan off until the head is installed with all it's rocker arm gear. (don't ask me why... )
Now there has to be a story there!
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Mon Mar 10, 2008 6:21 pm
Thats fer when yer dropping crap down da whole.....like dem lil thingies under the rocker stand boltz.
PostPosted: Mon Mar 10, 2008 9:27 pm
Sandy has done it also... I can tell!
I used to think that nothing can get dropped into the pan from the top of a SL6... I was wrong.
Pushrods can not get past the cam, the little rocker arm hold down 'thingies' are two big to get thru the drain holes but once I had to unscrew a "too loose" rocker arm adjustment ball stud and managed to drop the part into the lifter gallery... what are the chances that IT WOULD DROP THRU INTO THE PAN???? (it did) :oops: :evil:
We spent hours fishing the ball screw out thru the oil pan drain hole, we should have left the darn thing in there or just pulled the oil pan, it would have been faster! :roll:
That is why I do not put on the oil pan until the top end is "buttoned-up"!
PostPosted: Tue Mar 11, 2008 5:46 am
As a young (19 yearold) marine engineer I did it on a 3000 hp Mirrlees diesel. I didn t get a lunch or coffee break for months after that. I became" the guy that dropped the wrench". It was a 7/16 BSW wrench that should not have been in my hip pocket at the engine tops during refit......
I didnt learn a thing...I put my pan on before I put the head on... <shrug>
PostPosted: Tue Mar 11, 2008 7:19 am
YUP seen what a 3/8 ratchet extension does to a T50 turbine engine.
Doc is there/would there be any advantace to using a coating on the valves to help prevent carbon buildup? Ive heard somewhere that polishing them to a mirror shine really helps. Thoughts??
Thanks
Again for these build threads ( you too Sandy)
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Mar 11, 2008 7:57 pm
Cranked the Guzzi motor today,Got fuel,no sparky yet,gotta read directions,behind on goal,THINK it will fire tommorrow,will be posting pics later this week,Mark
PostPosted: Tue Mar 11, 2008 8:45 pm
Sandy,
Where did that wrench end up and how was it retrieved?
