It is currently Thu Jun 04, 2026 10:01 am
 Post subject: Cutting the head
PostPosted: Sat Mar 08, 2008 8:59 pm
If you shave the head down .10, do you have to get different pushrods?
Wylde Bill
63 Dodge 330
00 Sportster Rigid Bobber
05 Dodge Stratus (Wifes)
PostPosted: Sat Mar 08, 2008 9:02 pm
Maybe, maybe not. You will have to check upon reassembly though. :shock:
PostPosted: Sun Mar 09, 2008 6:49 am
If you shave it .100" and retain a stock cam - - most likely.
If you go to a higher lift cam maybe not; the adjusters will take up the extra length.
High Lift cams have smaller base circles.
PostPosted: Sun Mar 09, 2008 10:18 am
I didnt need shorter push rods on mine. Be careful and cc the head first. my cr is now 9.8:1 and i have to run 89 octain fuel.
PostPosted: Sun Mar 09, 2008 10:48 am
I cut my head and block for .10 and reground the stock cam to a higher lift. The stock push rods were right on the money.
 Post subject: Erson 270 cam
PostPosted: Sun Mar 09, 2008 12:27 pm
I'm probably going with the Erson 270 cam to give it some more punch since the car is pretty heavy. Four doors to move.
Wylde Bill
63 Dodge 330
PostPosted: Sun Mar 09, 2008 12:29 pm
my 4-door is under 2900 pounds
 Post subject: My four door
PostPosted: Sun Mar 09, 2008 12:34 pm
My four door is a 330 B-body. A bit more than your A-body in sure.
Wylde Bill
63 Dodge 330
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 8 guests
