It is currently Fri Jul 17, 2026 4:15 pm
PostPosted: Tue Mar 11, 2008 3:05 pm
Where is the proper location for the coolant sensor? There are two installed on my car. One is install on the leading edge of the head in a bushed down half inch pipe thread opening to the water jacket that has a metal thermal carrier to a cheap aftermarket tem. gage. The second is just threaded into a bolt hole on the forward end,carb side, of the head adjacent to the valve cover with the factory pickup, just a few inches from the first.
PostPosted: Tue Mar 11, 2008 3:58 pm
You describe the correct location but I’ve only seen one sensor there. Here is a picture that may help:
Danny
PostPosted: Tue Mar 11, 2008 4:08 pm
wish i could remember wut the other one was for... danny do you have a pic of the rest of your engine bay. i think i just nutted
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Tue Mar 11, 2008 5:49 pm
Thans for the nice view, and the proper location. This is the spot the crappy after market junk is located. It shall be fixed.
PostPosted: Wed Mar 12, 2008 4:31 am
Sadly, that isn’t my engine bay. I didn’t have any pictures of mine with a good angle of the temp. sender. One day maybe... But mine looks more like this right now:
Users browsing this forum: Amazon [Bot] and 12 guests
