It is currently Tue Nov 17, 2026 9:41 am
 Post subject: Hurst OD Shifter
PostPosted: Thu Mar 13, 2008 11:58 am
Hello,
I'm going to buy a hurst shifter for the 833 OD trans I have. Is it the same shifter used on non-OD transmissions? OR do I need a special part# for the OD shifter? Mine is an A body tailshaft.
I need one with a reasonably short handle that curves back for a street rod project.
Thanks in advance.
Mike
225 m90 supercharger model T roadster project
PostPosted: Thu Mar 13, 2008 12:17 pm
Same shifter. Buy your handle separately.
 Post subject: Ditto...
PostPosted: Thu Mar 13, 2008 7:43 pm
I would agree to that, if getting a junkyard shifter, any dodge/plymouth truck up to 1987 with the A-833 OD tranny will also have the shifter (but the lever and the linkage will be too long...)
good luck,
PostPosted: Mon Mar 17, 2008 10:32 am
I'm using a truck shifter handle in my A body, rev is a little close
to the wheel, but works fine.... the standard
3-4 shift arm will not work from A unless you mod it......
OD applications have their own 3-4 arm.
http://imageevent.com/jeffc/scampworks? ... =4&s=0&z=2
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
