It is currently Sat Jun 20, 2026 11:50 pm
Post new topic  Reply to topic  [ 102 posts ]  Go to page Previous 13 4 5 6 7 Next
PostPosted: Thu Mar 13, 2008 12:09 pm
Poser
:shock: Damn!!! :shock:
PostPosted: Thu Mar 13, 2008 12:19 pm
Also will the clear plastic fuel filter TECH out there? I have heard some discussion that it had to be a metal one???
I carry the metal one in the "race box" and have had to change-out the clear plastic fuel filter at a couple of events....
I tend to use the clear plastic fuel filters when starting new engines, just so I can see what is happening with the fuel supply. It makes it easy to see if you have water, rust or.... no fuel. :oops:
PostPosted: Thu Mar 13, 2008 4:03 pm
doug what is the brand of head gasket you are using? i had one a few years ago that had a tacky surface and held up very will i thought it was a mc cord but when i order one it wasn`t the same. what did you ring gap end up at? i have been using a .024 top ring and .018 second ring with a 3.48 bore. the fisher damper is it a bb after market and were are they available? :?:
PostPosted: Thu Mar 13, 2008 4:33 pm
Mark/Guzzi motor
PostPosted: Thu Mar 13, 2008 4:37 pm
http://www.fisherconcepts.net/
It apears they make one for the slant six.
Jess
PostPosted: Thu Mar 13, 2008 4:48 pm
The head gasket is one of the Permaseal, big bore gaskets from Austrilia.
There has been some talk about doing a group buy to get a few more shipped to the US. I think Lou did the last group buy on these.
I set the top ring gap at .022 and the second at .016 so we are pretty close in our thinking. I am running these forged piston on the loose side @ .004 clearance.
PostPosted: Thu Mar 13, 2008 4:52 pm
Doc, have you use these balancers on slants before? They seem to be of good reputation, but this is the first I have seen them. If they can tame a Hog that speaks a lot for them.
In the pics above, the filter element for a top has been proven on many apps to casue a loose of power. Not saying it will but I would test with & without it. It seems they disrupt the airflow to the carb in such a way to cause problems on some.
Jess
PostPosted: Thu Mar 13, 2008 7:07 pm
Thanks Doc Looking good Mark.
Cant wait for track reports from these 2 motors. :D :D :D
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Mar 13, 2008 8:23 pm
Un hooked summit msd box,dropped in points dist,5 stabs later,it re fired,I will add ballast rersistor tommorow,and get timeing closer.
New radiator has small leak,draining oil,and changeing filter,dip stick clicking and walking up the tube,gotta change the angle of the dangle,open headers do sound bad ass,did put pep boys angle down ,temp pipes on headers to direct exhaust away from firewall,closer,,,butt a long way away,,,
I gotta get my other rear end in my Signet that I will be driveing to Vegas,On the air filter top,remember the top of my hood is open,dont know if that will help or hurt but looks bitchen,also i will run 1 headlite,the other one is ducted to eng compartment,if you look at pics you will see the hole.
13.99 seconds away from being happy.mark
PostPosted: Thu Mar 13, 2008 8:57 pm
wow that so clean when its just bare bones...
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Thu Mar 13, 2008 10:04 pm
Yes,as Doc told me,,,,,10.min a day,adds up,again he is right,think motor was dropprd off and stuffed less than a month ago,I can only work on this 1 day a week,BUTT,i sneak in 20 min a day,fugure my 20 are the same as his 10.Mark
PostPosted: Thu Mar 13, 2008 11:05 pm
i just noticed that your alt is on the other side as well... hmmmmm?
PostPosted: Thu Mar 13, 2008 11:32 pm
Did that to shorten belt and give me more room on right side,mounted cd ignition box in that space,mount for alt is a modified smog pump bracket,top bracket is all thead with hiem joints for adjustment,alum tubeing over for cosmetics ,a modified 1 wire chevy 60 amp alt,left over from my other car,it needed over 100 to feed the stupid stereo,cut,grind,bleed,Mark
PostPosted: Fri Mar 14, 2008 6:16 pm
MadMax/6, I dont know how a open hood will effect the air cleaner. You just might want to try it at the track with the filtered top and with a regulor top. I agree they do look real good dont they. But test I have seen on dyno's has shown the filtered tops to cost power, it seems to be causing turbulance in the carb throat that causes the problem. I dont know if it will cause you any problems but thought I would meantion it, then when your at the track you can try both ways and see what happens. If it doesnt hurt anything your good. All you can do is try these things sometimes, what hurts one setup may help the other, you never know without trying.
Jess
PostPosted: Fri Mar 14, 2008 8:05 pm
Thank you for mentioning it,would hate to run 14.01 and not be able to do better,put a solid lid on it and break 14,something that simple would have been overlooked by me.Thanks again,this list is GREAT,mark
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
