It is currently Mon Jul 13, 2026 9:21 am
PostPosted: Thu Mar 13, 2008 7:51 am
I picked up an 80 Volare with a /6 for my son's first car. It has been sitting several years but it runs and drives. Right now is has the original 1bbl but I picked up a super six setup that will go on over the summer.
I have been searching the posts for the best selection of tune up parts adn have come up with the following list:
Standard Blue Streak dist Cap CH-410x
NAPA Echlin Rotor MO-3000
Auto Lite Spark Plugs (not sure if the number is XP26, APP26 or AP26)
Wires ?? I was just going to get a good quality 7mm silicon set from the local parts store.
Am I on the right track here?
Is the electronic dist and ignition on the 80 sufficient or should I be considering the HEI upgrade.
Thanks,
Scott
PostPosted: Thu Mar 13, 2008 8:49 am
Scott
Dont forget the Kickdown linkage for the Supersix, 2 1/4 exhaust to the muffler and The HEI is a good upgrade from stock. While your there do the Fuel Line Mod.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Mar 13, 2008 8:55 am
The supersix setup I found had everything: throttle cable, kickdown, air cleaner, intake, exhaust. It has the carb too but probably needs a rebuild.
Scott
PostPosted: Thu Mar 13, 2008 8:57 am
Scott
Cool glad you got everything. Ive seen some people that havent and got everything done then OOPS.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Mar 13, 2008 9:25 am
I knew to get everything from reading this board!!!!
PostPosted: Thu Mar 13, 2008 11:43 pm
As far as plugs go try the NGK vs the Autolites. The 80 would proably need the UR4 or the UR5 i can't remember which is the stock replacement
'66 Barracuda super six turbo??
PostPosted: Fri Mar 14, 2008 6:09 am
Thanks, I have been running NGK's in my bikes for years but never used them in a car.
Does anyone know a good source for the Blustreak Dist cap? I cant seem to locate it locally.
Scott
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 3 guests
