It is currently Fri Jun 19, 2026 11:52 pm
 Post subject: Rod bearings and me...
PostPosted: Mon Mar 17, 2008 9:27 pm
I ordered a set of rod bearings for my car, 73 Scamp w/ the 225. The ones I got were too wide, like 1/8" too wide at least. The PO said he swapped in another /6 because the original threw a rod. Is there a way to tell what motor I have (if it isn't a 225) and what year it's from so I can get the right parts?
Maybe I got the wrong bearings, but I don't think that's the case. Other than the width, everything fit fine. The "locator" tab on the bearing fit good and that side of the bearing was located correctly, the entire "too wide" part was all on one side. The fit and everything else was good.
1973 Plymouth Scamp
PostPosted: Mon Mar 17, 2008 9:51 pm
You have a 1977 and newer cast crankshaft 225 Slant 6
Exchange the bearings for the later set and you are good to go.
PostPosted: Mon Mar 17, 2008 9:56 pm
6 Pack Dart
you have a Cast Crank motor, they use narrower bearings, try '80s something 225, to get the correct narrow bearings.
PostPosted: Mon Mar 17, 2008 10:06 pm
...The "locator" tab on the bearing fit good and that side of the bearing was located correctly, the entire "too wide" part was all on one side...
As they say, you learn something new everyday...
I would have thought the unevenness would have been centered. :?
This means that I will have to do some additional measuring before I narrow a set of 198 con rods to fit on a cast crank.
Sounds like I will have to take more material off of one of the sides in order to keep the bearing centered.
PostPosted: Mon Mar 17, 2008 10:31 pm
If you need standard size cast crank rod bearings I have a set you can have for postage.
PostPosted: Tue Mar 18, 2008 2:57 am
I appreciate the offer on the bearings, but I need a .010 set. Is the engine that's in the car now better or worse? I'm still fairly new to these cars and engines.
1973 Plymouth Scamp
PostPosted: Tue Mar 18, 2008 6:38 am
Either engine is fine. Just a matter of preferance.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Mar 18, 2008 5:55 pm
In theory a forged crank is stronger but unless you're using the engine for extreme service, such as racing using nitrous or a supercharger you'll never see the difference.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
