It is currently Sat Nov 14, 2026 2:02 am
Post new topic  Reply to topic  [ 65 posts ]  Go to page 1 2 3 4 5 Next
 Post subject: Coil on Plug Conversion
PostPosted: Mon Mar 17, 2008 10:07 pm
I was wondering if anyone has tried to convert the slant six to coil on plug? I have been considering it for my next project.
PostPosted: Mon Mar 17, 2008 10:15 pm
distributorless igntion will still need a cam/crank sensor for the trigger... and an ecu to control it
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Mon Mar 17, 2008 10:23 pm
I put some passing thought into it. Right now I'm running Ford EDIS controlled by megasquirt. It would be trivial, electric wise to convert to COP. No major (electrical) re-engineering to do. May have to run dual modules to get more current on the primary side. Mounting the coils would be the trickiest part. This would be kind of cheating though, it would still function as wasted spark.
I thought I read about some megasquirt firmware that could drive individual coils per cylinder.
What ecu were you thinking about for COP?
PostPosted: Tue Mar 18, 2008 6:17 pm
It's something I plan to try next after my turbo upgrade. It shouldn't take nearly as long as the turbo has taken. :) My plan is to do a dyno shootout and see how coil on plug compares with a MSD 6A firing the distributor. I've already started setting up a crank trigger for it.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Tue Mar 18, 2008 6:34 pm
is the ford edis waste spark?
PostPosted: Tue Mar 18, 2008 8:19 pm
Yep it is. Easy way to tell - coil packs have one wire for the positive feed, and one negative wire per pair of coils.
PostPosted: Wed Mar 19, 2008 6:21 pm
isnt that a way to determine the mated pairs as well...?
PostPosted: Wed Mar 19, 2008 6:36 pm
Not sure what you mean by mated pairs. There are diagrams on the msns/msns-e sites of which plug towers equate to which pins on the harnes connector.
PostPosted: Wed Mar 19, 2008 11:16 pm
im just speakin mated pairs on the cyls. like when two pistons are goin down at the same time regardless of which cycle they are on...
PostPosted: Thu Mar 20, 2008 5:48 am
They're 3 cylinders apart on the firing order.
PostPosted: Thu Mar 20, 2008 1:13 pm
1 5 3 6 2 4
1 & 6
5 & 2
3 & 4
You'll notice that the members of the pairs are split between the front 3 cylinders and the rear 3 cylinders and the symmetry of their locations
PostPosted: Sun Mar 23, 2008 6:21 am
Good explanation Ems!
Sam
PostPosted: Tue Apr 08, 2008 9:01 pm
I know this is a silly ? but how deep are the spark plug tubes? Or another way of asking is how long would the coil need to be?
This is a 3.2 chrysler coil
1970 Vitamin C Duster 225 2bbl 904 eventually turbo efi r154 5 speed
1969 B5 blue roadrunner 383/727 soon to be turbo slant (JK)
1972 Barracuda was green 318 who knows?
PostPosted: Sun Apr 20, 2008 6:28 pm
i would assume a little shorter than that. you gotta rember that those coil on plugs typicly go through the valve cover as well so they gotta be a bit longer...
PostPosted: Sun May 18, 2008 5:09 am
What's the advantage of the coil on plug?
