It is currently Wed May 27, 2026 9:48 am
PostPosted: Tue Mar 18, 2008 3:21 pm
will a gas tank and such from a 4 door valaint fit into my 72 duster ?
1972 Plymouth Duster 225 Super Six Slant
 Post subject: Yes...
PostPosted: Tue Mar 18, 2008 4:09 pm
You can use any 1967-1976 A-body gas tank, although there are some variations in the tank venting in the later models, and the 'strap' is different in the 1967 model...
PostPosted: Tue Mar 18, 2008 4:53 pm
this is proably a 70 to 72 valiant
 Post subject: seat
PostPosted: Fri Mar 21, 2008 6:20 pm
Car Model: '63 Dart GT Convertible
I got the front seat from a mid-70's 4-dr Dart. The seat is kinda like buckets with an arm rest in the middle. It didn't fold foward for entry to the back seat, but if you look under the side cover where the back meets the bottom seat cushion you will find a piece of steel with a set scrwe holding it in place. What I did was remove this piece of steel and replace it with the latch from a 2dr Volare. Fits right on, holds the seat back from comming foeard and when needed works perfect for tilting foward. So, just something to think about while there.
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
PostPosted: Sat Mar 22, 2008 5:52 am
The venting can be an issue as D.I. mentioned. Compare the number and location of the vent tubes on your car to the one you're considering buying and try to get one that is the same. The later models (74 and later?) have more emissions stuff with extra vents to deal with. Let us know what you come up with.
PostPosted: Sat Mar 22, 2008 7:00 pm
well rob I have already bought the tank and my duster is a 72, The valant proably the same year because in 73 duster and valiant changes im very smart on those to car's and there looks
