It is currently Wed Jun 17, 2026 7:04 am
 Post subject: rim size?
PostPosted: Sun Mar 23, 2008 5:43 pm
I am going to run a disc brake conversion on my 74 valiant and i just picked up some 14" disc brake rims off of an 80s ford at the junkyard. my question is will the 7 1/2" wheel clear the upper a arm. i noticed my 14" wheel thats on the car right now the outer edge of the wheel is the same height as the upper a arm. any help would be appreciated.
PostPosted: Sun Mar 23, 2008 5:50 pm
You may have to machine down your rotors so the Ford rims can fit over the rotor hub.
Are you sure they are 7 1/2"rims?
PostPosted: Sun Mar 23, 2008 6:03 pm
where do you measure rim width? the rotors fit. i supported both sides of the inside of the wheel and pressed an old rotor through. the hub was only a few thousandths off from fitting. then i lightly sanded the wheels hub area and they slid in smoothly
PostPosted: Sun Mar 23, 2008 6:18 pm
Rim width is measured from bead seat to bead seat across the wheel.
PostPosted: Sun Mar 23, 2008 6:23 pm
ok its probably 7" wide then thanks
PostPosted: Sun Mar 23, 2008 6:38 pm
How much backspacing do they have? You can fit 7" wide rims but not if they have too much backspacing - or too little. Around 4 1/4" is just about right.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sun Mar 23, 2008 6:44 pm
thanks ill have to check that
