It is currently Tue Oct 13, 2026 12:10 am
 Post subject: Engine Tear Down
PostPosted: Fri Mar 21, 2008 11:01 am
hey ya'll Brad here from Ga. alright well i decided to tear apart my '62 plymouth SL6 ..and i was wondering if i could get some help?
i have the head and all o fthat mess off but i cant get the cam out.... also i cant get the oil pan out of the car...yes i am trying to leave the block in the car, bad move but i dont have a cherry picker of an engine stand.
also i was gonna replace the vitals, i.e. gasgets and such but i also wanted to do a cam swap any ideas on which brand-?
thanks Brad
-1962 Plymouth Belvedere SL6
-1994 Volvo 854
PostPosted: Fri Mar 21, 2008 11:37 am
Pull the engine out of the car.
Rent a cherry picker or use a looped strap and a long pole stuck thru that, and get 4 strong friends to help lift the block out.
PostPosted: Fri Mar 21, 2008 11:50 am
i guess i'll have to do that..any ideas on engin parts..i plan on doing everything except taking apart the block...but i do want a newer cam
-1994 Volvo 854
PostPosted: Fri Mar 21, 2008 11:58 am
i know this is a dumb question but i cant get the cam out..i have the oil,fuel pumps out abd he dizzy...but i cant get the lifters out ...??
-1994 Volvo 854
PostPosted: Fri Mar 21, 2008 12:14 pm
what about this cam woud it work?
COMP Cams 64-240-4
http://store.summitracing.com/partdetai ... toview=sku
-1994 Volvo 854
PostPosted: Fri Mar 21, 2008 12:50 pm
6 Pack Dart
to get the lifters out, try using a pair of the wide-blade spap ring pliers. Reach down from the top and catch the lifter by the inside lip on the top of the lifter, rotate as you lift.
That would be a pretty mild cam.
PostPosted: Sun Mar 23, 2008 7:31 pm
THANKS about the lifters...so what cam would be a good choice?
-1994 Volvo 854
PostPosted: Sun Mar 23, 2008 9:07 pm
I am running that cam spec. and it will still get you good mileage and provide a good amount of spunk with out any drawbacks. I kept my original cam and had it reground to that specification.
What are your goals?
Are you rebuilding it to be near stock?
or rebuilding it to be a hot street car?
PostPosted: Sun Mar 23, 2008 9:25 pm
welllll..its kinda a rebuild to stock with pep..sooo a more powerful cam, and exhaust would be nice...but the interior is custom, and so will the audio, so it will be some what of a retro/mod. but i will be classy...and im not too worried about the mileage as i will not be taking it out for long trips, i took a trip to fl. from Georgia, it was a 6 hour drive and i about killed my self ( but there were no floor boards soooo that really sucked)
but new gaskets, intake, cam, exhaust manifold/ headers, muffler (if i use one) ..possibly a new or rebuild carb. that is what is on my mind...
BTW i have the two blr. intake manifold but no car 4 it, if i were to use it i would have to get the kick down linkage right?
-1994 Volvo 854
PostPosted: Sun Mar 23, 2008 9:33 pm
Yes, if you have an automatic. You can get them off eBay if you can't find a car with it.
Don't toss old stock carbs. New ones or good rebuilds are hard to find that are any good. You may want to try and rebuild what you have and rebush them when they need it.
PostPosted: Sun Mar 23, 2008 9:48 pm
im just gonna keep the stock carb set up...but get it rebuilt and the intake cleaned...
so any ideas on a cam?
-1994 Volvo 854
PostPosted: Mon Mar 24, 2008 6:22 am
Go to the parts for sale section, look at the Erson cam group buy sticky, Call TOM order what He reccomends. Probally a 270 would be good.
My 02.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
Users browsing this forum: Amazon [Bot] and 19 guests
